Bravo 1 increase negative trim cutting trim rods >
Old 09-13-2022 | 05:51 PM
cig28's Avatar
I’m going with cutting the rods and taking a small piece out and weld them back together. My winter project.
cig28 is offline
Old 09-13-2022 | 08:31 PM
What are you planning to use to cut the rods? You're not going to take the rods out of the trim cylinder and cut the ends where the bolt attaches?
Don_Juan is offline
Old 09-14-2022 | 08:06 AM
cig28's Avatar
I’ll cut the rod with cut off wheel about an inch back from where the hinge pin is and take 1/2 to 3/4 out. Chamfer the edges, Reweld it but still be able to use the zinc. I’ll have to take the hinge pin out to see how much further in the drive tucks in.
cig28 is offline
Old 09-16-2022 | 04:33 AM
MikeScarab28XLT's Avatar
You can only cut out that pice that the drive can swing down without the rams hang in. If you cut more out and you trim down you damage the Gimbel ring hing pins with your ram power.
MikeScarab28XLT is offline
Old 09-16-2022 | 07:56 AM
cig28's Avatar
You are correct I was looking at a boat at the marina I work at and the drive will only go in until the bell housing hits the gimble ring. So I have to make sure to cut the rams so that the bell housing does to touch the gimble ring.
cig28 is offline
Old 09-16-2022 | 09:10 AM
Will it hit the gimbal ring if you only take 3/4" off the rods? Do you have a pic?
Don_Juan is offline
Old 09-16-2022 | 10:08 AM
You should also allow a "little" extra room for the compression of the rubber mounts when with load in forward.
Falcon is offline
Old 09-17-2022 | 08:34 AM
cig28's Avatar
I think it will definitely hit the ring if I take 3/4’s off. I’m going to get the right measurement when I take the hinge pin out to see how much more negative there is to play with.
cig28 is offline
Old 09-19-2022 | 06:42 PM
Well after going to remove the trim cylinders today, I realized the drive already hits the gimbal ring. It appears I have some negative trim. It looks like a lot of work to shorten the rods, trim metal on the drive and maybe off the gimbal ring just to get a little more negative trim. I'm thinking there may not be much benefit in the small amount of increased negative trim I might be able to get.
Don_Juan is offline
Old 09-19-2022 | 08:40 PM
At least you were smart enough to look it over before you did a bunch of work for nothing.
Smitty275 is offline
