cleaning resevoir
Old 02-19-2026 | 07:39 AM
brake cleaner, the spray straw helps eliminate the rag and screwdriver, spray shake repeat....
30outlaw is offline
Old 02-19-2026 | 08:42 AM
Active Streak: 30 Days
Diesel fuel. Pinch off the hose and remove the reservoir, put in a shot or 2 of diesel, let it soak. Put a rag or shop paper towel in there and use a screwdriver to swish it around and soak up the gunk. It is better to disconnect the hose if you can get it off w/o breaking the fitting.
Helmwurst is offline
