Go Back  Offshoreonly.com > Technical > Electronics
SmartCraft Gateway For Northstar >
Old 12-27-2014 | 09:27 AM
Default SmartCraft Gateway For Northstar
Before I buy a new one, I thought I would check if anyone had a used one they would like to get rid of...or if anyone had advice for, or against it.
Have a Northstar M84 that I would like to get data to.
Thanks!
ryanot1 is offline
Old 12-27-2014 | 06:10 PM
I have a M84 with the SmartCraft in it....what are you looking for?
Pwraddr is offline
Old 12-28-2014 | 04:07 PM
Thanks for the reply. I am just looking to get any and all information I can get. Fuel usage, alarms, fault codes, etc... Anything you dont like about yours? Any data you dont get that you wished you did?
Thanks,
Ryan
ryanot1 is offline
Old 12-28-2014 | 07:58 PM
I have one on my lowrance HDS7 and it pulls in more information that you will ever need. Alarms will only go off on the data pulled into the system. For example, IAC valve went bad and I go the beep alarm through the boat electronics but through the smartcraft gateway. I have a Baja 25 outlaw and it doesn't pull fuel level, apparently I need a fuel level sensor connected from the sending unit to the nmea2000 network
joketchum is offline
Old 01-19-2015 | 04:40 PM
Opening this back up for discussion again.
I cannot find this gateway. It is a discontinued product. Nearly every site reflects this. A few that did not reflect "out of stock" or "discontinued" I tried, only to get a notification later that it is not available.
Anyone know where I might be able to source one? Am I just out of luck?
Simrad Twin Engine Smartcraft Gateway - SKU (CWR-28804) (AA010188)
Thanks in advance!
Ryan
ryanot1 is offline
Old 01-30-2015 | 05:50 PM
check out e bay one pops up occasionnaly
tazdevil is offline
Old 02-05-2015 | 06:37 PM
I know nothing about electronics, but my boat was rigged with a Northstar gateway but has a Simrad GPS. I'm assuming they're interchangeable
509 SC is offline
Old 02-09-2015 | 09:59 AM
I found this one on this website http://www.veradoclubparts.com/produ...-8m0065208.htm im trying to find where I bought mine last spring and it was about 325 dollars. As soon as I find it I will send you the link
Old 02-09-2015 | 10:38 AM
Here is where I ordered mine from but their prices have gone up http://cheapmercuryparts.com/8M00652...ATWY%20MULT%20
Old 02-09-2015 | 11:50 AM
Thank you for this information, joketchum. What display are you feeding this to on your boat?
I "guess" this would work with my M84. The manual only speaks of a smartcraft gateway, but not NMEA2000. I could assume that is the protocol it is receiving, but that's an expensive assumption. Also, I do not currently have a NMEA2000 network, but it looks like it comes with everything I would need.
ryanot1 is offline
