Go Back  Offshoreonly.com > Technical > Electronics
Running a second amp >
Old 05-21-2015 | 09:38 PM
Originally Posted by HyFive578
Yessir. Circuit breaker near the battery to cut the current in the event the main cable gets severed or something really bad happens. I guess a fuse would achieve the same thing potentially, but because of the location in the bilge, I went with a heavy duty circuit breaker cause I knew I'd end up stepping on the fuse all of the time and breaking it. I also added a house battery for my amps and tied it to my center engine with an automatic charging relay that has starting isolation. Works like a charm. When the engine is running, it combines and charges both batteries.. if either battery voltage drops below 12.75 volts, it disconnects them and when I start the engine, it automatically, disconnects them as well...
sorry for the hijack, but this info could be helpful to OP..
picture of my amp wiring below...
[ATTACH=CONFIG]541241[/ATTACH]
Nice job on the wiring,very clean! Where did you get the distribution blocks with built in fuses?
509 SC is offline
Old 05-22-2015 | 01:56 PM
Thanks. I'm a bit of nut when it comes to this stuff. It was a lot of wires so I wanted to keep it neat so I mounted everything on a piece of 1/4" starboard.
The distribution block is a JL Audio (XD-FDBU-4) 4-Way Fused Power Distribution Block. I believe I ordered it and the 50A fuses for it from their website.
HyFive578 is offline
Old 05-22-2015 | 09:27 PM
Thanks, I got a bunch of new JL speakers and amp going in soon. I'ld like to make it as sanitary as possible!
509 SC is offline
Old 05-23-2015 | 08:56 PM
Who runs a capacitor? What farad?
endeavor1 is offline
Old 05-24-2015 | 08:17 AM
Doubt you need a cap.
turbo rr is offline
Old 05-26-2015 | 01:22 PM
Can you run off of the remote and ground from the 1st amp?
Abs777 is offline
Old 05-27-2015 | 10:34 AM
jonyb's Avatar
A cap is not designed for reserve time, and won't have a purpose in a boat. It stores energy for when current draw is needed - like when bass hits. That's only applicable in a car/truck, and it's to help take a little load off of the alternator. In a car, it's a band-aid at best.
jonyb is offline
Old 06-09-2015 | 07:35 AM
I ran my second amp and I used the power distribution block for my power and ground. Now I am getting interference from my new amp when I run the blower. Do you guys think this is a grounding issue? It's weird that the ground is ran from the distribution block to both amps and only one is giving me feedback.
Any ideas?
Thanks!
Abs777 is offline
Old 06-09-2015 | 05:03 PM
Dirty power is fairly common in mobile systems. Could be a ground loop issue. How are amps grounded and the blower?
happy hours is offline
Old 06-09-2015 | 05:18 PM
Any ideas?
Thanks!
When you say you used the power distribution block for power and ground, does the block you used have a separate ground terminal post and what did you tie that back to ?
