SmartCraft Fuel 2
Good morning
I own a Mercruiser 6.2 MPI, after mounting the electrical system, and mounted indicators smartcraft fuel 1 and 2 fuel, I realized that the original engine in the plant is not scheduled line for the fuel sender 2.
Do you have ideas to solve this problem?
Thank you
Thank you
How many fuel tanks do you have? If you only have one, you configure tank 1 and set tank 2 to "Not Installed. Also, you can do a master reset on the gauges and set everything back to the factory settings.
