Go Back  Offshoreonly.com > Technical > Electronics
Tranducer location on a stepped hull Donzi? >
Old 01-03-2017 | 12:15 PM
Cignificant's Avatar
Default Tranducer location on a stepped hull Donzi?
I've decided to use an in-hull transducer for my Garmin 547XS. Any suggestions on a mounting location? Mid-hull, towards the stern, before or after one of the steps?
Steve Gresham
'03 Donzi 33ZX
Cignificant is offline
Old 01-03-2017 | 12:31 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Steve,
If you can get access forward of the first step, this would be best. This way you know when you are creeping up on shallow water when beaching or the like. I do not believe the bottom of the hulls are cored on your boat.
Sydwayz is offline
Old 01-03-2017 | 08:26 PM
Behind the steps will not work on plane. Hull is very thick and will not shoot through without drilling into
Wilks is offline
Old 11-19-2020 | 07:52 PM
Bringing back from the dead. Where did you end up mounting the transducer?
rcarroll is offline
