Go Back  Offshoreonly.com > Technical > Electronics
good depth finder >
good depth finder
good depth finder
Old 01-29-2019 | 01:05 PM
Default good depth finder
looking for a good depth finder - my current lowrance cant handle more than about 10mph - would like one that works better at speed. thanks
JST1970 is offline
Old 01-29-2019 | 09:18 PM
Never seen any depth finder work over 10mph
Griff is offline
Old 01-29-2019 | 09:32 PM
My Airmar in hull will work at 50mph most times.
underpsi68 is offline
Old 01-30-2019 | 12:39 AM
BUP
some is wrong then with your Lowrance or the transducer or the install . At one time thats all my dealerships would install because they were so reliable.
Which unit do you have and how old ? Have you hit your transducer and how is that installed ? they can not read air -- Is the transducer transom mounted or shoot thru the hull -- The can NOT read thru a cored hull FYI - has to be solid glass with no air bubbles between the laminates if the transducer is shooting thru the hull. Just saying
BUP is offline
Old 01-30-2019 | 10:46 AM
Transducers can't read through air. They need clean water under with no bubbles. If you want to read at speed it has to be placed so that is maintains clean water under. A stepped hul introduces water under the hull making it harder to find clean water.
Like mentioned it can read through fiberglass but not any material with air pockets. If mounting to read through the hull it is expoxied to the hull. No air bubbles in epoxy.
You can test it's location by temporarily attaching to hull and flooding area with water so it fill voids between hull and transducer. Then run at speed to test.
justfishing is offline
Old 01-30-2019 | 10:57 AM
mine is mounted in antifreeze.
Old 01-30-2019 | 11:48 AM
Lots of good info thanks!
JST1970 is offline
Old 01-30-2019 | 12:43 PM
I have this one and it works great:
https://buy.garmin.com/en-US/US/p/530269
Diamond Dave is offline
Old 01-30-2019 | 01:14 PM
BUP
baby oil is the recommendation for the transducers to be submerged - including the airmans.
BUP is offline
Old 01-30-2019 | 01:16 PM
BUP
I posted they can not read thru air nor core material sandwiched between glass. I do not know if you read that or not or ? just saying
BUP is offline
