Results of 5 Blade Maximus on my 2007 Daytona
Get a hold of BBlades Professional Propellers. He is the Maximus Expert. If they are not labbed that is your problem. YOu can get 400-600 RPM out of labing a Maximus. You may be able to turn labbed 32s which will give you more speed and mid range. Labbing them will also get your RPMs to synch.
I'm pulling my boat out of the water Fri to prep it for the Ft Meyers run - I will check the xDim on both drives to ensure they are true.
On my way back from the run, I am signed up to take Tres Martin's class - in my boat - really pumped about this trip - will be interested to gain his insight as well.
I'll post on my progress.
Is there any downside for installing Stallings Stand off boxes? - what's the rough cost per side?
We have several older 28 TDs in our area running 625 - 750 NA engines with very few drive problems.
Some run XZs and some run XRs. Some run Bravo 1s and some run 5 blade props depending on the X dim.
I run temp gauges on my drives and about every 100 hours the temps raise a bit and installing new bearings in the drives takes care of it.
The guys running Wipples or 900 - 1200hp blower motors in our area are tearing up drives all the time.
The weather really effects this lower HP boats- With my 07 28 ICC 496 x 2 power i really can tell now the air/water temp has warmed up a bit.
At Havasu during the winter it was easily pulling over 100mph with a full load and stock bravo 30p.
During desert storm - loaded with gas and people i had a hard time obtaining anything over 95 mph ! But it was 100 degress out...
Now i switched to my labbed 30's so we'll see how it does this weekend.
BTW- I had a high water pressure code due to the through hull pickup being too long. This retarded my timing so i couldn't pull the RPM needed- something to think about as before Absolute Marine found the code my boat never ran over 97mph. Instantly once they cleared the code and shaved 1/16 off the pick up it went right to 104 mph. A tip for those boats that aren't running the top speed over 100.
Dave
Dave
Dave
Dave
Chris288
10-06-2004 10:33 PM
