Exterior paint on Das Boat is done. Engine bay clean up now...
LOL Im glad u guys like it. I used a Honeywell or similar I think I paid 300 bucks. Its 8000BTU. I would like 10000 but this one works. Its nice because you dont have to set it up on a hatch cover, and it sends most of the condensate water into a built in evaporator. I did rig up a condensate drain line that after about 12 hours I drain it into a solo cup and dump it overboard. If you dont want to keep it onboard you could just bring it when ya need and leave it dockside when the weather permits.
Honeywell 8,000BTU Portable Air Conditioner with Remote Control, Black (MF08CESBB)
Yea its pretty straight forward way to go. I only keep the water out of my bilge because im such a freak it would probably be almost zero discharge from those AC units : ) Mine stays onboard and is semi permanent, I just plug it in while dockside if its real hot out and it seems to do the trick.
Alrighty then.... almost done with the engine bay and new hatch I'm building. Next thing to do is deck furniture. I don't want to build a rear bench or captain's seat out of plywood and fiberglass. What ideas would you all have that might work. I was looking at some seats from a pontoon boat (hear me out....) that fit perfectly but the captain's chair would need to have a metal brace to sit on and raise it up. It doesn't look bad, matches the theme of the boat, and looks like it was made to fit. I'm jsut wondering how well this would hold up to heavy abuse. It's an idea for now, but not what i settled on. What other ideas do you guys have that might work?
Barnacle my rear seat is just made out of marine plywood and covered in foam and vinyl. It is a pretty simple setup that works quite well. It is also removable and it is what the factory did back in the day. Is it just that you dont like the look of the built in?
I had the built in stuff, but it was too heavy. If I didn't cover it in resin or plywood, it would easily rot. I literally ripped out about 600lbs worth of seating.
