Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
How to get wax off rubber or hard plastic trim >
Old 09-12-2006, 10:29 PM
Default How to get wax off rubber or hard plastic trim
What do you use??? CHEERS AW
obads 31 is offline
Old 09-13-2006, 08:29 AM
Were doomed!
Wally's Avatar
Default Re: How to get wax off rubber or hard plastic trim
try simple green and an old tooth brush
-Wally
Wally is offline
Old 09-13-2006, 03:59 PM
Thanks WALLY I'll try that maybe with a stiff nail brush that has a grip on top. Anything else besides simple green ??? CHEERS AW
obads 31 is offline
Old 09-13-2006, 07:04 PM
This is kind of after the fact but... before I wax a car or boat that has plastic trim (especially black) I be sure to apply a protectant to the plastic like 303. Not only does it protect from UV light it prevents wax from getting in the plastic and there is no need to clean it in the first place.
You may want to try WD-40 then follow with regular vinyl cleaner, then 303 of course!
4mulafastech is offline
Old 09-14-2006, 04:37 PM
frenzy's Avatar
Waxing Frenzy! Seriously, it will remove the wax from those areas. Keep that in mind, also, next time you buy wax. You don't have to protect the rubber or hard plastic trim...the frenzy does it for you.
frenzy is offline
Old 09-15-2006, 03:20 PM
CROWN MAN's Avatar
Rubbing Alcohol , But not in the sun
CROWN MAN is offline
Old 09-15-2006, 07:09 PM
bowtie's Avatar
Acetone
bowtie is offline
Old 09-16-2006, 09:06 PM
THE waxguy used a product "back to black" seemed to do the job, and thanks for the suggestions. CHEERS AW
obads 31 is offline
kds
Powerplay
5
05-08-2008 09:28 PM
handfulz28
0
10-30-2007 10:49 AM
cheitman
11
05-20-2003 09:40 PM
SmilingBob
05-04-2003 01:37 PM
Quick Reply: How to get wax off rubber or hard plastic trim
