my winter project
#61
Scippy.....Well I have the as you say shoe box style hull as well. The inside of my hull was glassed already I'm guessing from the factory, so all I had to do is the outside. I took a grinder and grinded in between the hull and the deck. Then I crammed it full of Cabaseal to get everything nice and flush then laid a lair of mat over that to tie it all together. Then grind and shape it and put a good skim coat of alexseal gray fairing putty to smooth it all out nice and get it ready for primer. I will be bending the SS rub rail around the bow bend & corners .And im getting the flat half round from a local boat supply warehouse. Hope this helps you if not let me know.
#62
[QUOTE=ridefast77;3789177]Scippy..... I will be binding the SS rub rail around the bow bend & corners .
Define "Binding"..............................Thanks Scippy
#65
[QUOTE=ridefast77;3789905]
Of course, the old fashion way, bend!!
"Bullet proof and attractive" the strenght of the hull and look you will achieve when your all done.........Nice!!!
#69
Did the yard show any concern when the idea of flipping your boat was discussed?...... was a waiver dicussed "if things go horribly wrong?.......2 yards now completely rejected the notion of using there equipment to flip my boat.......I'll find a yard (plenty here in Jersey) and get it flipped eventually. The issue of Liability is no doubt a concern.
#70
RF77,
