Rattling silent thunder syndrome >
Old 04-13-2005 | 11:21 PM
CObarry's Avatar
Default Re: Rattling silent thunder syndrome
Bill, I'll check it out this weekend, but why do you have to remove the ladder?
CObarry is offline
Old 04-14-2005 | 12:26 AM
Bill272's Avatar
Oops, my mistake. I was thinking that the ladder studs went through the silent thunder box, but looking at it it apparently does not. It's been a while since I took it off, and I was posting from my foggy memory of it. lol
Actually the ladder bolts were a problem for mine too. One of them hit a spot on one of the center exhaust chambers and made a hole there.
The 200 lb older style platform makes sense. The newer style is not structural at all and doesn't have to hold any weight, except for the water that fills it.
Bill272 is offline
Old 04-14-2005 | 10:29 PM
wantsa311's Avatar
Originally Posted by offthefront
I NEVER heard a rattle .....then ........Outlaw just happened to mention a rattle .....THEN thats all I %#$#@$%^& could hear was rattle .....
I had my platform off this winter and as Iggy sez the partitions were loose ..we glassed em back in and now quiet as a mouse .... ....Mine is older style box .... A ***** to get off and on ......I would think the newer style would be ez fix ..
OMG !!! I'm gonna have to listen for rattles as soon as I can splash it !!! Probably not 'til the middle of May the way work has been going.
wantsa311 is offline
Old 04-14-2005 | 11:52 PM
Poorsche's Avatar
Here's an alternative to Silent Thunder box. Made out of 1" Starboard with 1" structural braces where brackets support and 1" structurals that run from side to side. Extends 30" from transom at widest point. Weight about 80 lbs.
With the transom mufflers noise level is about same as thunder and a lot more mellow.
We drew up design in Autocad and cut the Starboard with CNC laser cutter. We're thinking about marketing them if there's an interest.
So far no stains from exhausts on platform--about 6-8 hours running.
Attached Thumbnails Rattling silent thunder syndrome-swimplata2-1-.jpg   Rattling silent thunder syndrome-swimside1.jpg   Rattling silent thunder syndrome-swimplata1.jpg
Poorsche is offline
Old 04-15-2005 | 06:12 AM
Formula Outlaw's Avatar
Your platform looks very good...
Formula Outlaw is offline
Old 04-20-2005 | 12:20 PM
powerguy's Avatar
Originally Posted by CObarry
OK, I know most will say to dump the silent thunder and go with regular thru hulls (and I will eventually), but is there a way to bondo/duct tape/super glue the thing to stop the rattling at idle? What is it that's rattling....baffles? Only happens on the port engine...the starboard side is fine...
Had the same issue with the rattling box on my 336..... sounded like you were dragging a buch of cans behind you......also had the same thoughts about fixing it.....decided to take it off completely......the thru hulls sound really loud compared to the silent thunder box.......installed HPI transom mount mufflers and it still sounds great and looks great with the new muffler tips.
"All I need are some tasty waves, a cool buzz and I'm fine"
powerguy is offline
Old 04-28-2006 | 04:43 PM
CObarry's Avatar
** Update **
Forgot to update this thread earlier, but I found that the rattle was from an old & tired exhaust flapper, not the ST box. It was a much easier fix than taking the whole box off....
CObarry is offline
Old 04-29-2006 | 06:37 PM
t500hps's Avatar
21 and 42 footers
FYI: I removed the Silent Thunder box off my 312. STILL RATTLES! Turns out the swim ladder is the culprit.
t500hps is offline
formula2?2
07-30-2017 09:54 AM
ninetym
07-02-2008 09:58 AM
sneekinfreek
10-12-2007 10:47 AM
S4Hadi
03-03-2006 01:35 PM
Gearhead2
05-13-2005 07:04 AM
