Clearance for Dart Manifold >
Old 01-21-2002 | 08:12 PM
Post Clearance for Dart Manifold
Need some help here..
repowering 1990 242LS with a 540 Ci motor.
Does anybody know if a Dart manifold will fit under the hatch or how much room is available. My boat is currently covered for winter and won't be available untill March
Sheikman
sheikman is offline
Old 01-21-2002 | 11:31 PM
Scott72
Post
I measured the clearance under the hatch of my 223 with a stock 330 hp 454 and I had almost 10 inches from the top of the stock flame arrester to the bottom of the hatch. Not sure if a 242 is the same, but I assume it is similiar. I am in the process of building a 454 and wanted to be sure a single plain and a taller spark arrester would fit (which they will on the 223).
Old 01-22-2002 | 11:42 AM
JON242
Post
On my 86 LS242 there is at least 8 inches clearance between my 4" K&N flame arrestor, atop a Holley carb, atop a Dart Kool Kan intake(same as a edelbrock air gap) on a small block. I think you'll have plenty of room.
Old 01-22-2002 | 04:36 PM
blown formula's Avatar
Post
I installed an HP454 with a Dart intake & Procharger blower (enclosed carb box) in my 93 252 Sunsport. This combo should be the same height as a dart intake, carb & flame arrester.
I had plenty of clearance for the carb, manifold and blower box, but had to raise the front edge of the engine cover 3/4 inch to clear my intercooler. This is easy with a hand saw, stapler & 1x2 wood strips & carpeting.... just remove the seat cushions (on mine anyway) & cut the wood to fit, wrapped the pieces in carpet & screwed them down to the edge of the carpeted bulkheads. Reinstall the cushions & its hard to tell anything had been done (if your carefull). Unless you have a real "high riser" you should be ok. You could just measure the manifold height of a stock intake & the Dart. Call Formula tech & he can give you the clearance as manufactured.
blown formula is offline
SkaterWear
Skater
0
10-24-2008 09:20 AM
Tony Montana
3
08-01-2008 04:09 PM
Jassman
Active Thunder
20
10-01-2007 08:45 AM
Kanookstr
8
04-04-2004 06:50 PM
