Need a speedo, sell me your old one? >
Old 05-30-2005 | 09:37 PM
292SR1's Avatar
Default Re: Need a speedo, sell me your old one?
See your 292 Thread.
I was 70 by old VDO prior to nosecones and Stainless Marine exhaust. Maybe a true 67?
I did the exhaust, Imco Nosecones, and Nordskog GPS speedo all at once. Boat picked up 300 rpm to 5350 so I had to ditch the 23 Mirage (old style..original to the boat?) for Mirage + 25's. So now 70 on GPS at 4950. Would guess I picked up 3 MPH, 5 on a good day which I am happy with.
Do some searching aroung OSO. From reading other owners posts I probably should have gone with Hydromotive 4 blades.
Others know more about the Hydromotives than I do.
292SR1 is offline
Old 05-30-2005 | 09:48 PM
axapowell's Avatar
Where To
I've got your new speedo!! PM Me
Dave
axapowell is offline
Old 05-30-2005 | 09:58 PM
5speed's Avatar
My boat is a 1988 and has had motors installed. Said they where 420 motors by Carolina Performance . OK What I do know is they are Gen5 454,s no fuel pump mounting on block, With ( Zuzs ? ) Alui. intakes, with stock carbs and exhaust. It was pulling 5000 rpm not full throddle with the belts squeeling so that was that. Have just got boat back from shop to fox the steering and installed 25 p Mirage props. What is the difference in the + and the reg.
5speed is offline
Old 05-30-2005 | 10:44 PM
5speed's Avatar
Wink Re: Need a speedo, sell me your old one?
Originally Posted by Magicfloat
Hey Thanks for the link
5speed is offline
Old 06-01-2005 | 05:19 AM
5speed's Avatar
Originally Posted by chuck21401
Yeah, I have an inexpensive GPS by Garmin. It doesn't work quite right because the speed never reaches 75mph.
I guess I'll pull the speedo and water tube and see what is going on in there. If I change to a different style speedo then I would just have to change all of the guages to match!
What have you decited to do about the GPS. I want to buy one but have know idea . I have motor home that I would like to use it in, and on the boat. I was thinking battary, But they are to small to read ( old eyes). And the Boat and the Car have Cig. lighters for 12V. Help
5speed is offline
Old 06-01-2005 | 12:34 PM
chuck21401's Avatar
Hijackers...all of you!
Anyway I monkeyed around with the speedo pick up tube, it had become disconnected. I reconnected the tube...but speedo still didn't move. I haven't determined if the tube is blocked or kinked or if the speedo is kaput.
I put that project on hold because the recirculating pump on the motor is leaking so that needs to get fixed first. It is always something.
chuck21401 is offline
Old 06-02-2005 | 05:59 AM
SSComp's Avatar
You can check the gauge buy using an air compressor:
40 mph 21.84 psi
50 mph 34.13 psi
70 mph 66.89 psi
90 mph 110.56 psi
As you can see the small lines they put on these are usually not capable of the higher pressures. Most likely the line.
SSComp is offline
Old 06-02-2005 | 08:43 AM
chuck21401's Avatar
[QUOTE=SSComp]You can check the gauge buy using an air compressor[QUOTE]
Thanks for this info...I was wondering how to test the speedo...
Old 06-02-2005 | 08:47 AM
axapowell's Avatar
Where To
Chuck,
I have a replacement VDO if you need it...PM Me
Dave
fountainfevr
Fountain
2
04-03-2008 07:25 PM
carrboy
9
03-16-2007 06:47 PM
Jonas
Fountain
20
04-09-2006 07:51 AM
Dave98
1
10-06-2004 10:54 AM
88 MACH 1
4
03-07-2003 01:31 AM
