finally wet and speed #'s >
Old 06-22-2005 | 06:57 AM
Default finally wet and speed #'s
finally launched yesterday. the day was without incident.
had everything detailed and in the same place for once.
that in itself makes for a pretty good day!
I think there is a low-end torque loss without the restrictor plates under the riser. 2-3000 RPM. Revs a little quicker from 4-5000 though it seems. makes sense.
Yesterday was windy 15-20SW, so there was a stiff wind and 1-2 chop going downriver.
496 HO's, Corsa's, full bag of gas, and plenty of gear, me.
26 Bravos (polished stock)
5000 RPM on the nose both ways.
trim 5-6
no tab
73.8 downriver
71.2 back into the wind
those Corsa's without the end cones sound.......just right.
Attached Thumbnails finally wet and speed #'s-truckboat3.jpg   finally wet and speed #'s-truckboat5.jpg
Rippem is offline
Old 06-22-2005 | 07:05 AM
offthefront's Avatar
Default Re: finally wet and speed #'s
I am really looking at the 496's .... while I have been reluctant to go to EFI but you know its the future .. with the Raylar kits 550+ hp .....
offthefront is offline
Old 06-22-2005 | 07:23 AM
Team V's Avatar
Looks good Rip
Nice job on the upgrades!
I hope to launch July 1st
Team V is offline
Old 06-22-2005 | 08:38 AM
I haven't tried those props yet. I was running late and realized I didn't have the right spline nuts (I only have the long Bravo hubs around now). I got a pair now. I really needed to establish beaseline with the Bravos first anyway. I'll note speed through RPM range and planing ect before I try them.
If you need them say the word, or grab them, they are in the garage on the same bench.
Rippem is offline
Old 06-22-2005 | 10:40 AM
Team V's Avatar
No problemo... I won't be needing them until after the July 16th run, and even then there's no hurry...
Team V is offline
Old 06-28-2005 | 02:16 PM
Nice looking package
rolln in it is offline
Old 07-12-2005 | 03:56 PM
mcr
Is That The "normal" Trim Range For This Setup? I Have A 353 W/502's And Have Been Told Not To Trim Over 3.5?
mcr is offline
Old 07-12-2005 | 04:14 PM
mopower's Avatar
Toxic FORMULA
I would say it depends how the indicators are adjusted. Mine takes 6 to 6.5 to be even with the bottom of the boat. Takes 7 or better to trim it up.
mopower is offline
Old 07-12-2005 | 04:18 PM
that's when my boat stops picking up speed.
There is >0 delay in my indicators...sometimes that little delay some have, can mean a half a pin or more difference out in the trim range, boat to boat.
Had it 71.4 GPS yesterday in 90+ degree heat.
half fuel
two people
lotsa gear and beer
nearly full waste holding tank...
yea, I know...
too much information.
EDIT: and it's been in the water a month...the bottom is looking it...
Rippem is offline
Old 07-12-2005 | 04:50 PM
so I one thing is apparent...
consistency
those engines make good cruising torque and are what they are for horsepower...though it appears it's available everyday.
as I get the NavMan fuel system closer in cal, it's interesting also, how consistent fuel consumption is at various speed settings
I'm getting ~1.5 NMPG at a variety of speeds from 2800- to near 4000 with appropriate trim and no tab, or just a windage correction
this is right on with the Formula performance report I got my hands on well before the buy of this boat.
that's 1.5 MPG from 35 to near 60 MPH!
this is only 10-12% more fuel at similar speeds than my 454 Mag 32 Velocity (floscan equipped ) which was a very efficient boat.
Hats off to formula for the 353 hull
and to Merc for very sound black package
Rippem is offline
