Another Engine Hatch Problem - Solved !!! >
Old 07-10-2005 | 07:47 AM
wantsa311's Avatar
Smile Another Engine Hatch Problem - Solved !!!
I got my hatch lift working again. After checking all the wires and determining that there was power to the lift I took it out to inspect it.
Since it was dead anyway I took apart the electric motor and - low and behold - there is a little thermal protection circuit with a bimetalic spring that had fallen apart. I got out my soldering iron, bypassed the circuit and WHOO-HOO I'm back in business.
There is a circuit breaker under the dash for the lift so I'm sure I'm okay without the internal one. The lift is really a linear actuator designed by Warner Electric for industrial applications. The original purpose of the lift was for factory usage with a heavy duty cycle and the motor might overheat so they put in the internal protection circuit. Since opening and closing the hatch a couple times a day isn't really a heavy duty cycle it'll be okay.
$250.00 dollars saved to give to the gas dock.
wantsa311 is offline
Old 07-10-2005 | 10:24 AM
Formula Outlaw's Avatar
Default Re: Another Engine Hatch Problem - Solved !!!
"Don't you love it when a plan comes together".
Formula Outlaw is offline
Old 07-12-2005 | 11:02 AM
Glad it worked out nicely and thanks for the info!
ThirdBird is offline
ratman
4
08-23-2005 07:34 PM
wantsa311
08-18-2005 11:26 PM
G Man
0
07-16-2005 10:31 AM
johnkot
0
06-27-2004 07:48 AM
Ron P
OPA/The Jersey Boyz
1
07-15-2003 11:33 AM
