Bouncing H20 Temp Gauge >
Old 07-22-2005 | 09:03 AM
Default Bouncing H20 Temp Gauge
One of the water temp gauges on my old 311 seems to "bounce"- the needle sort of hops up and down erratically. Boat is not getting hot or anything and I am getting plenty of H20 through the pump, block and exhaust. Is this a sender issue or am I seeing the beginning of the end of my temp gauge?
SeaWeasel is offline
Old 07-22-2005 | 11:05 AM
Default Re: Bouncing H20 Temp Gauge
Make sure all the connections are tight.
boomer is offline
Old 07-22-2005 | 09:49 PM
offthefront's Avatar
make SURE all is ok ..... Steam pockets can make it jump around ....
offthefront is offline
Old 07-23-2005 | 01:32 PM
Formula Outlaw's Avatar
I have the same issue with my starbord water temp guage. Replaced the sending unit but didn't make a difference. Checked all connections, seem okay. Figure the guage is wearing out. I just keep an eye on oil pressure. If motor gets too warm, oil pressure will drop.
Formula Outlaw is offline
Old 07-26-2005 | 12:41 PM
Bikini Bottom's Avatar
My left engine temp cycles from about 165-180 and then cools back down. The right stays pretty consant near 160 degrees. Oil pressure is stable, don't know if it's a thermastat issue or w/in normal operation. Anyone have a similar indication?
Bikini Bottom is offline
Old 08-02-2005 | 09:12 AM
My 91 292 acts identical to Bikini situation. Spoke with mechanic at Chesapeake (former Full-Tilt) and he says the original VDO gauges have this issue. If your gauges are original, may be time to look at an upgrade. I am going to a new set of Gaffrig in the off season.
Treads is offline
Old 08-02-2005 | 10:09 AM
Treads- this is the same advice my mechanic gave me on the issue. His position is that VDO needs to GO . . . . .
masi242
10-23-2008 10:38 AM
mittens
5
09-23-2008 07:42 AM
speed demon
7
07-01-2007 09:58 PM
97BossHammer
8
03-25-2003 02:50 PM
