No more Silent Thunder boxes... >
Old 09-10-2005 | 11:11 AM
  #31
C_Spray's Avatar
Diamond Member #001
Default Re: No more Silent Thunder boxes...
I ran the Silent Thunder box from 2000 to 2004, but was continuously breaking brakets with the vibrations from my Innovation 600's. Once I made stronger brackets, I started breaking the bolts!
This is a set of custom, externally-switchable exhaust tips that CORSA made for me. Since my engines have Stellings headers, the through-hub option was not available to me. When the flaps are shut, the exhaust is diverted out of the slots in the bottom of the mufflers. I cut the slots myself, but made them too big, so there is very little reduction in noise. I plan to re-do the system over the winter so that the diverted exhaust runs down the transom and exits underwater. These mufflers have a very nice rumble to them. The engines were VERY loud with straight headers and flappers.
C_Spray is offline
Old 09-10-2005 | 02:54 PM
  #32
Originally Posted by BigDaddy96
My 353 does not have the box, only the corsa mufflers but unfortunately it still vibrates my swim ladder at idle. Kind of annoying
have you got the foam mat on the floor of thw ladder compartment?
never hear a peep from mine.
no rattles whatsoever.
Rippem is offline
Old 09-10-2005 | 04:45 PM
  #33
BigDaddy96's Avatar
I do have the mat. I tightened all the screws up back in July as well, but that did not help much. I wonder if the mat needs replacing?
BigDaddy96 is offline
Old 09-10-2005 | 06:42 PM
  #34
C_Spray's Avatar
Diamond Member #001
Originally Posted by TRICK
...What is that on top of the mufflers? Looks like an additional bracket to support the weight???
Fred
Yep. The headers stick through the transom at a 20 degree down angle. If I had installed clamp-on mufflers, they'd be buried in the water off plane, and I was worried about inversion (and the looks). I made up the 14 degree spacers, bolted them to the transom, and then bolted the mufflers to the spacers. The mufflers are almost 22" long, so I made up the stainless brackets, installed threaded brass bushings into the fiberglass, bolted them up with rubber bushings and clamped the mufflers to the brackets with t-bolt band clamps. Solid as a rock. Hated working with the stainless, but loved the way it looks. Here's a closeup.
C_Spray is offline
Old 09-10-2005 | 11:47 PM
  #35
firstoffshore's Avatar
Very nice Chuck!
I agree. Leave it to Chuck to come up with something that innovative.
firstoffshore is offline
Old 09-11-2005 | 08:48 AM
  #36
Formula Outlaw's Avatar
My silent thunder box was a BIT(H to get off. Ended up having to mill a 2x4 narrowing it down to a basic "point" after about five ft. It was almost at some point, someone had reinstalled the box with 5200 or something similar. It was NOT your typical gasket sealing material. Anyway I had to get a 3 lb. maul and hammer the wedge between the box and the stern of the boat, VERY CAREFULLY. Took me about an hour but it worked great. Couldn't believe how heavy that sucker was.
And yes, all the bolts were out......
It wasn't leaking though.
We don't have sound issues down here. 90% of offshore boats in our neck of the woods run "straight thrus" with no problems with law enforcement.
Guess the Porters would not like my boat, it ain't that quiet anymore.
Everyone who has seen the boat, and knows boats, has really complimented me on what I have done.
Formula Outlaw is offline
Old 09-14-2005 | 07:10 AM
  #37
Looks nice Fred.
alot more room to cook and clean back there now huh?
Rippem is offline
Old 09-15-2005 | 08:40 PM
  #38
Looks good Fred....
Sounds better too....
Old 09-15-2005 | 09:49 PM
  #39
dukenrock's Avatar
Fred,
If the boat looked that good when I had it I'd still have it! Nice job!!
dukenrock is offline
Inspector
4
06-04-2008 09:52 PM
sneekinfreek
10-12-2007 10:47 AM
S4Hadi
03-03-2006 01:35 PM
augie58
02-27-2006 10:02 PM
scarab97
4
06-17-2004 09:56 AM
