292 FASTech on the way!! >
Old 10-26-2005 | 05:56 AM
  #51
Default Re: 292 FASTech on the way!!
Originally Posted by NICKM
While we're kind of on a 292 kick here, the new vette 6.0 engine has 400 hp with cat converters and all the other things that limit power in a car. The Escalade with the 6.0 truck engine has 380 hp. So why does the mercury engine that requires 0 emissions only put out 320hp???? Any one have an answer for that?-Nick
Plus, I believe the HP output is measured at the propshaft. You can add another 30 or so at the crank.
ThirdBird is offline
Old 10-28-2005 | 12:02 AM
  #52
aquaforce's Avatar
The working load on a vehicle engine is very low compared to a boat engine. If this same engine were put in a boat it would not last very long. Much like the difference between the working relationship of a car and a truck. If you slapped a 400hp small block from a car into a truck and tried to pull a large boat down the road, the engine would detinate itself apart.
aquaforce is offline
Old 10-28-2005 | 07:52 AM
  #53
Looks like they got the SC5000 monitor in there with the Monster tachs
So....with the SC5000 you don't need a separate GPS unit like the Garmin 172 C chart-plotter?
Does the SC5000 track and record way-points and destinations?
What are the benefits of having both the Garmin 172C chart plotter and SC5000? If only one could be chosen which would be the better pick?
Venomous is offline
Old 10-31-2005 | 10:19 AM
  #54
I really don't know all the features the SC5000 offers related to GPS. I believe you need to have a GPS plugged into it for those features to work. Once I get it home and have a chance to read up on everything I will let you know. I mainly spec'd the SC5000 for the engine monitoring features, but will likely get a GPS down the road.
By the way, just received the picture below from Formula. She just got out of the test tank and it ready to be masked and taped for paint. Should be done on Wednesday.
4mulafastech is offline
Old 10-31-2005 | 10:12 PM
  #55
dukenrock's Avatar
That boat looks great all white!
...wouldn't mind getting a hold of one of those dollies
dukenrock is offline
Old 10-31-2005 | 10:40 PM
  #56
offthefront's Avatar
Sure does
offthefront is offline
Old 11-01-2005 | 12:09 PM
  #57
In the paint booth... so much for being all white! Actually, most of that color will come off with the tape. That's why I like the #3 design...
Attached Thumbnails 292 FASTech on the way!!-wrocklage292pic14.jpg   292 FASTech on the way!!-silver-3-series-graphic-barbados.bmp
Old 11-01-2005 | 05:16 PM
  #58
bouyhunter's Avatar
That's awesome to have all the build photo's of YOUR boat.
I've been shopping for a while now, I'm stuck on an older Cigarette, but the wife is really interested in the Formula's.
This thread is making look a little harder at Formula's.
I've known since I was a kid that they are a great boat.
If I pulled the trigger on a Formula, it would likely be the 292.
But, I think I'd leave it all white for the first season, then consider some subtle custom paint work.
All these new graphic scheme's (from almost all boat builders) are bit too much for me.
I loved the old "hockey stick" paint, maybe just some updated color combinations - the orange and brown of the early to mid 80's just doesn't cut it. The old Cigarette red/black/silver is still a classic look though.
I saw a thread on here somewhere of a Formula that was painted all Silver on the hullsides, with black accents, looked great.
Good luck with the new toy.
bouyhunter is offline
Old 11-01-2005 | 05:21 PM
  #59
bouyhunter's Avatar
OK, I'm a dumbAzz - the silver and black is C-spray's
it's about 4-5 threads down....
Old 11-01-2005 | 05:39 PM
  #60
Like this ???
