382 Prop suggestions
Originally Posted by Troutly
Ah nooooooooooooooooooooo. Running them on the rocks outside Bayou Bills at LOTO is tough on the props!!!!
I'll be calling you in a month or two to hook me up with some Maximus wheels. No sense putting the $$$ into fixing the hydros when I really want some five blade round ears on the old girl
I noticed in the pics of your VERY NICE! boat, that you're spinning in. What's your call on that? Handle good/bad? Faster?
I'm also turning in. It takes a little more anticipation and finess in tight docking sutuations especially in windy conditions, but I have never noticed any ill-handling at speed and the wake is really flat like Troutly stated. I do not know if it made any difference in speed at WOT as the boat was set up this way when I bought it.
Prop results, 382 2003 w 525's Stellings and no mufflers.
Light load with factory supplied 31 Bravo One's labbed 5250 @ 81.5.
Light load with Hydromotive P5 labbed 28's 5100 @ 81.8.
Light load with Hydromotive P5X 27 stock 5300 @ 80.8.
P5X labbed and up pitched to 27.5, Not tested yet- too rough.
P5 labbed and down pitched to 27, Waiting for them to come back.
I'll get back to you guys when I can get good test conditions.
John B
John B
Crit, Bravos really blow on this heavy boat, especially with boxes. This is close, B1's are from Formula test, Hydros are actual.
31B1L 28P5L 27P5Xno/L 27.5P5XL
3000 30 42 38 37?
4000 51 61 57 58
John B
3000 30 42 38 37?
4000 51 61 57 58
John B
John B, and Everybody else
Thanks lots for the information, it's been very helpful.
I think we are going to start out with a set of Labbed 28 x 15.25 Maximus and go from there. Based on the rpm numbers from the 28 Labbed B1s we've been running. the Maximus props should be pretty close to what we're looking for.
Tom
Tom
Finally got a chance to test the Hydro P5X labbed and 27.5 pitch. This was in the Fla Keys on the Miami Boat Show Poker Run last weekend. With 6 people, bags and coolers plus 120 gallons of fuel, we ran for 10 miles experimenting with trim and ultimately hit 80.0 on GPS at 5380 +-on digital tacks. Total weight was probably 12600 lbs. I thought this was unbelievable for the weight. Only problem now is I need more pitch since we were just hitting the rev limiter. BTW the optimum trim was right about 7.
John B
John B
