question for 311 owners .... >
Old 03-25-2006 | 07:41 AM
offthefront's Avatar
Default question for 311 owners ....
same question is in the progect thread but just incase someone misses it ..... replacing the stringers in my 311 and need to know if on the outside stringers .. there is a notch about 24" from the front bulkhead in the stringer. I am thinking it is where ther battery cables dropped down under the motors. can somebody look and see if I need to go back with them ? If it is for the cable we might just punch a hole thru the stringer ... Just need to make sure its not there for clearance for the motors... thanks m
offthefront is offline
Old 03-28-2006 | 06:52 AM
Default Re: question for 311 owners ....
come on ...you guys pull the cover and let me know ....
Old 03-28-2006 | 07:11 AM
Ted G's Avatar
Sorry I didn't see this before, I was down Sunday. If you don't get a response I will be back down to the boat by the weekend and I'll look for you. But looking at it, it might be where the fuel pump/water separator is located and they had to notch it for that.
www.cbpba.com
Ted G is offline
Old 03-28-2006 | 07:20 AM
you may be right ... I was thinking it was where the grd cable fed to the block but it makes more sense for the fuel pump .......m
one thing though is fuel pump/filter on port motor is on Starboard side of motor ....
Old 03-28-2006 | 04:35 PM
wantsa311's Avatar
Sorry, Mike - I'm tucked away until April 15th. Hopefully you'll be back together by then.
wantsa311 is offline
Old 03-28-2006 | 07:02 PM
Ya got that right ! .. thanks anyway Bob ..someone will chime in ....m
Old 04-02-2006 | 10:10 PM
Ted G's Avatar
Okay, got it for you today. On mine the alternator bracket on the port motor reaches into the notch. They ran the negative cable through the notch on the starboard side-probably just cause it's there. The fuel pump/water pump assembly on the starboard motor doesn't come anywhere near the notch. So you can get away without it on the starboard side but not on the port.
www.cbpba.com
Ted G is offline
Old 04-03-2006 | 04:25 AM
CMG's Avatar
CMG
surprised to see a 311 need stringers repaced at all!
Chris G.
CMG is offline
Old 04-03-2006 | 05:04 AM
Insptech .. Thanks ... timing is perfect .... mike
wantsa311
05-29-2007 08:30 PM
SeaWeasel
06-08-2006 07:25 AM
Chris
05-28-2006 10:40 PM
SeaWeasel
03-28-2004 09:13 AM
SeaWeasel
10-01-2003 07:05 PM
