my nemesis=====black dash >
Old 05-13-2006 | 07:05 PM
mopower's Avatar
Toxic FORMULA
Default Re: my nemesis=====black dash
Originally Posted by Treads
MOPOWER, those panels look very nice. Where did you get them, or have them fabricated? Would like some info if you don't mind.
The guy who did mine did a GREAT job. Duplicated my originals except I had the pass. side done in two pieces istead of three pieces . Also redesigned the helm for oil temp , fuel pres. and water pres. Unfortunately due to health issues , Mark from MearImage has seemed to have fallen from the face of the earth
mopower is offline
Old 05-13-2006 | 08:32 PM
Originally Posted by propwash
Hey Dgduck13, what did you do with the glass you took out of your boat? It is for a 311 right? When you removed the windshield did you have to support the glass and frame or was it self supporting? Thanks Propwash. Offthefront, nice job on that HUGH project of yours.
I ended up throwing out the glass when I made the move from MN to FL a little over a year ago.
The windsheild and frame are glued togther and is self supporting. When you remove the screws out of the bottom have a few friends around to help you carry the windsheild off of the boat. Otherwise you can take it apart in three pieces and carry them yourself. any other questions let me know.
Don
Maritime_Eng is online now
Old 05-13-2006 | 08:40 PM
mopower's Avatar
Toxic FORMULA
Where the screws be?? I heard they were above the headliner in the cabin
mopower is offline
Old 05-13-2006 | 10:51 PM
You are able to access all the screws from the top side. Pull out the foam/plastic strip from the bottom of the windsheild frame. You should see all the screw heads. The only two you will not see will be the last bolt on each side by the air vents. remove the triangle air vents and you should see these bolts.
East Coast B
Sonic
4
07-05-2007 07:51 AM
Boomer35
05-11-2006 07:43 AM
formula271
09-15-2005 03:18 PM
88formula223
06-06-2005 08:09 AM
