New plan.  Bigger Formula >
Old 06-30-2006 | 07:37 AM
  #81
Formula Outlaw's Avatar
Default Re: New plan. Bigger Formula
Originally Posted by 245 limited
From what I know,spinning the 3 blade props in will give the 311 about the same effect as a 4 blade,or very close to.
Maybe, but I've read differently on this Forum. I also believe turning the props in negatively impacts the "docking ability" of the boat. I think Troutly experimented with this a couple years back.
Basic math would tell you a four blade would have hipothetically 25% more bite than a three blade all things being equal, at least in theory.
But I'm NO prop expert.
I know the new Mirage Plus props are a big step up from the older basic Mirage units.
Formula Outlaw is offline
Old 06-30-2006 | 07:50 AM
  #82
Full Force's Avatar
My buddys 311 has no problem docking,he looked at 4 blades a while back and was told the top end would not be any more than what he had,his boat had no problem planing with 3 blade labbed 25's. I am amazed that you could gain the speeds you did.I have never heard anyone get that kind of mph for the mods done.is that on gps?
Full Force is offline
Old 06-30-2006 | 08:58 AM
  #83
formula1's Avatar
I went from 3-bladed Mirages (23P) to 4-bladed Bravos (24P). The difference is awesome! I picked up the same 6 MPH cruise speed, great holeshot, too. I don't know what top-end is... I always seem to have the kids and/or wife and I just don't run WFO with them in the boat.
I almost went with Hydros, but I found an awesome deal on the 24P Bravo's and that sealed the deal for me!
formula1 is offline
Old 06-30-2006 | 11:09 AM
  #84
I'm juppin in late; but I agree with Cuda. I'm running Kaama's and they have been trouble free, very simple to work on, and all bearings and seals are over the counter items.
And you gotta love those tails!
Attached Thumbnails New plan.  Bigger Formula-311-s-.jpg   New plan.  Bigger Formula-1drive.jpg
RiverRat311 is offline
Old 06-30-2006 | 02:33 PM
  #85
Yep....when you think about it, it's pretty easy to see how it's accomplished. I just eliminated an enormous amount of drag in the water which gave me the faster speeds. It is EXACTLY what Hydromotive told me what would happen and why. They nailed it.
You can add more hp, but if you have the same amount of drag, it takes so much more hp to overcome that same amount of drag. Less drag will gain higher speeds using the same amount of hp. Which is EXACTLY what happens when we trim our drives out at speed. Run your boat up to 4,000 rpms, then trim out the drives, and look how much faster the boat is. By getting my azz end higher in the water, I just basically got a head start.....
Kinda like raising the "X" demension, except my "X" demension stayed the same, the whole rear end of the boat is just higher out of the water.
Old 06-30-2006 | 02:40 PM
  #86
Full Force's Avatar
the 311 I am referring to at the time had aluminum heads and intakes,that is a ton of weight off the back of the boat also,big block iron heads are HEAVY!!!
  #87
Sure tough to debate that....
Old 06-30-2006 | 02:42 PM
  #88
83 lbs. per motor was the difference on mine. Plus losing the silent thunder box (older style) was another 200 plus pounds. Then you've got the Quad IV's kicking the stern up as well. There's the difference.
And that's not including any "water weight" trapped in the silent thunder box.....
One other thing, were/are you running in fresh or salt water??? Boats are faster in salt water, more boyancy.
Old 06-30-2006 | 02:46 PM
  #89
Full Force's Avatar
I realize that, I have a little pee pee small block and trim is everything!!
we hit 80 on gps with the aluminum heads and 525 cams on my friends 311,he talked to a ton of people about propping and was told by everyone that the 4 blade would not help top end,the boat had no problem planing at all,even with 6 people and lots of fuel.
My friend is very good with research and tried alot of different things also,he just figured he would buy a fast-tech with blowers instead!!!
Old 06-30-2006 | 02:47 PM
  #90
Full Force's Avatar
fresh water,so your engines are not stock mags? you have aluminum too?
