How much does Silent Thunder weigh? >
Old 02-07-2014 | 10:20 AM
I know this is a really old thread, but would any of you happen to know how much the OLD silent thunder swim platform weighs? I have an 89' 242ls and am removing it and putting on a nice tubular aluminum one, so light I can lift it with one hand! Just curious how much weight I'll be saving. Also Putin a 500+ horse engine in it while I'm doin that so it should run damn hard now
gmgearhead454 is offline
Old 02-07-2014 | 06:02 PM
offthefront's Avatar
Post #2 still applies ....
offthefront is offline
Old 02-17-2014 | 08:27 AM
Originally Posted by t500hps
After cleaning up (It's nasty in there) I had 1 small area where the box was rubbing under the swim platform. Left an area 1/2 by 1 1/2 inches that the gelcoat was rubbed down a little but unless you stuck your head under the boat and over the drives you really couldn't see it. When I had some bottom work done a few months later I had them fix that little spot since they had the boat anyway.
If you down like the boat without the box you can always put it back on......but I bet you'll never consider that once it's off!!!
You will want to fill the holes also from the bolts that held it on.
kevlar382 is offline
ninetym
07-02-2008 09:58 AM
mopower
11-11-2007 06:43 PM
sneekinfreek
10-12-2007 10:47 AM
Gearhead2
05-13-2005 07:04 AM
