First test ride tomorrow (272 SR1); final tips? >
Old 09-17-2006 | 06:33 PM
  #31
offthefront's Avatar
Default Re: First test ride tomorrow (272 SR1); final tips?
post 19 ... no Circulator pump .....only uses the raw water pump ...Some say it adds HP ... very little if any ... Some say it causes hot spots in the motor ... its an never ending debate ...mostly cleans up the front of the motor... I think some blower motors need the room .... look just below the thermostat housing at the front of the intake manifold ... Stainless pipe that ties both sides of the block ( water jackets) .....m
offthefront is offline
Old 09-17-2006 | 07:29 PM
  #32
cuda's Avatar
Some people claim to have to much water pressure with cross overs too. I have them on my 302, and have never had a problem with them.
cuda is offline
Old 09-18-2006 | 08:52 AM
  #33
Smile Re: First test ride tomorrow (272 SR1); final tips?
Originally Posted by handfulz28
Anyone want to hear about the boat ride?
Unfortunately, I'm no closer to bringing a Formula home. Biggest issue right now is starboard motor not wanting to run more than 4k RPM at WOT, and only showing 25-30psi oil at those RPMs. It's the original with over 700hrs so not surprising, just disappointing. The port motor with less than 10hrs had more in it over 4k RPM but I didn't want to get too far out of sync; and that motor was reading more than 80psi oil! Sheesh... The props are Stilleto M1421 which I assume are 14" 21P? Are these right for the boat? GPS indicated 45+mph at 3900RPM; how's that sound?
The other thing I need to learn about is the intake manifold/carb setup.
Michael
OK i have a 87 272 bone stock 614 hrs on 350 mags. I am running 23 mirages Last weekend i ran it with just me and my buddy 1/2 tank of fuel 56.5 gps@ 4200. i would think this boat would do the same. BTW my oil press is 20-30 port and 30-40 starboard. Iwould also check to see if one of the props are out of wack. When i bought mine one motor ran 5000 the other ran 4600. found out by swapping the props that one prop was bent I think 21's are probably the right pitch for the boat. Iwant to try some 21 mirages to see if i gain anything. I hope this helps
Car Biz is offline
Old 09-18-2006 | 12:10 PM
  #34
Thanks Car Biz for sharing your setup. I always thought 350s liked at least 10psi/1000rpm. I agree that I think 21s are probably the right prop. I have no idea if the timing is correct or if perhaps the throttle cable needs adjustment.
handfulz28 is offline
Old 09-18-2006 | 01:17 PM
  #35
Agreed 10 psi or better a 350 will live for along time. timing should be at 10 degrees. You could always buy my boat
Car Biz is offline
littledcsrodshop
05-14-2015 07:18 AM
lman
03-30-2007 01:35 PM
handfulz28
08-21-2006 06:07 AM
Clay Avedisian
02-16-2006 03:57 PM
Smokinlegend
11-30-2004 07:33 AM
