Aft screw in windshield moulding breaking >
Old 09-24-2006 | 09:55 PM
Default Aft screw in windshield moulding breaking
The aft screw in the stainless windshield channel keeps breaking. I thought about through bolting with a 1/4 20 bolt. any thoughts??05 382
382 newbie is offline
Old 09-25-2006 | 08:11 AM
RedDog382's Avatar
Default Re: Aft screw in windshield moulding breaking
The final fastener at the aft section of the frame should be a through bolt. I believe the factory install is through-bolted, although it is not very easy to reach the backing nut. When I removed my fairing and replaced it with a windshield, I through-bolted every one that I could reach.
RedDog382 is offline
Old 09-25-2006 | 08:16 PM
wantsa311's Avatar
RedDog - Was your 311 thru-bolted? I just tightend my windshield per your instuctions, none were thru-bolted, and I'm pretty sure it had never been apart before me. If it gets loose again I'll try the thru-bolts - sounds like a good idea.
wantsa311 is offline
Old 09-26-2006 | 06:06 PM
RedDog382's Avatar
Don't think it was but never looked at it. I did thru-bolt all the holes at the deck/hull joint where the rub rail is and it was much more solid.
Old 09-26-2006 | 08:03 PM
Charter Member #415
The W/S screws are long S/S self tapping screws with a white coating on the threads,kind of a high tech sealant to keep them tight. Never had a problem at all over the years.
Magicfloat is offline
Old 09-26-2006 | 08:31 PM
wrinkleface's Avatar
My 03's was a bolt w/ nylock nut underneath that I could not reach to replace when it became loose and came off! Good luck
wrinkleface is offline
rlv1017
05-14-2015 07:18 AM
Craig B
1
06-21-2007 03:32 AM
iamfaster
Scarab
11
01-30-2007 01:08 AM
Memphis
Fountain
8
10-18-2006 05:53 PM
Dregsz
Banana Boat
1
08-30-2005 09:19 AM
