mid 80's hull bow or stern lifting props? >
Old 11-05-2006 | 09:39 PM
Default mid 80's hull bow or stern lifting props?
Have 86 242 twin with alpha drives. Does this hull style bennefit more from a four blade stern lifter, or stick with the thre blades?
twin242ls is offline
Old 11-08-2006 | 11:08 AM
Iggy's Avatar
Default Re: mid 80's hull bow or stern lifting props?
Since you're running Alpha drives you may want to stick with three blade props. Four blades may be too much load for the Alpha to handle. "BOOM!!"
In swapping a Mirage prop for a Laser II of the same pitch I noticed my F206 doesn't need as much drive trim to carry the bow and at WOT the stern lifts. I can feel it in the seat of my pants, the stern gets a bit loose.
The difference between a Mirage and Laser II is the blade size (less area on the Laser), smaller outer diameter on the Laser II, and more blade rake (lifts the bow). I didn't gain speed, but it does come out of the hole easier.
Iggy is offline
Bryan Rose
1
06-14-2011 11:11 AM
ELITE711
Prop Talk
14
10-03-2007 12:33 PM
TeamSaris
08-31-2006 09:19 PM
Bryan Rose
Prop Talk
3
08-24-2006 09:21 AM
DRTOBE
5
04-08-2003 12:22 PM
