311 SR-1 Sundeck vinyl replacement? >
Old 03-26-2007 | 01:49 PM
Default 311 SR-1 Sundeck vinyl replacement?
Can you take out the individual pieces of vinyl to recover them?
MOERON is offline
Old 03-26-2007 | 06:31 PM
Yeah. Lift up the engine hatch. Remove the screws holding the mirrors in place. Under the mirrors are more screws holding the sundeck pieces in place. Remove the screws and pull out the sections.
Don
Maritime_Eng is offline
Old 03-26-2007 | 08:46 PM
Default Thanks Don!
Don
What would I do without you! Thanks for all the help.
MOERON is offline
Old 03-26-2007 | 08:56 PM
Thats what were all here for. I was in your same place a couple of years ago with the 311. How did the rub rail turn out?
Old 03-26-2007 | 10:29 PM
cuda's Avatar
I'd go ahead and replace the wood with pvc board, and put in new foam if I were you. It doesn't cost that much, especially since you will have it apart anyway.
cuda is offline
Old 03-27-2007 | 09:29 AM
Looks good I would up load pictures but the files are over the size limit.
MOERON is offline
Old 03-27-2007 | 09:48 AM
Download this:
http://www.microsoft.com/windowsxp/d...powertoys.mspx
Load this program. Then rick click on any picture in your folder and in the menu will be a picture resizer. Use the small format. It will resave the file in a smaller format. Its the easiest one I have found.
torpedoj
3
09-08-2012 04:33 PM
Dr Ralphy
Scarab
7
08-21-2011 04:13 PM
MOERON
07-23-2007 08:04 AM
SeaWeasel
08-12-2005 09:58 AM
SeaWeasel
05-23-2005 01:18 PM
