Flat Screen/DVD retrofit in 382 >
Old 05-01-2007 | 07:15 AM
C_Spray's Avatar
Diamond Member #001
Default Flat Screen/DVD retrofit in 382
This has come up a few times in other threads, but I did not have pictures of my retrofit until now. Like most 382's up until a few years ago, mine came with a combination 13" TV/VCR that came apart after 5 years. I found a TV/DVD that had both audio and video outputs since I wanted to hook it up to my stereo and a remote monitor in the cockpit. It's a bit of an off-brand, but at $400, who knows?
I made a complete new 1/2" plexiglas panel, using the original one as a template, but cutting a hole that fit the new TV. Since the disc ejects out of the top, I hinged it along the bottom and built a stainless steel support to mount both the TV and a clearance panel for the latches and to make sure an ejected disc did not trap the unit shut. I'm happy with the results, and wound up with a whole new storage area, although I need to tidy up the wiring back there....
Attached Thumbnails Flat Screen/DVD retrofit in 382-p1000398-large-.jpg   Flat Screen/DVD retrofit in 382-p1000394b-large-.jpg
C_Spray is offline
Old 05-01-2007 | 08:44 AM
88formula223's Avatar
NO WAKE ENFORCER
looks awesome....nice job
88formula223 is offline
Old 05-01-2007 | 12:21 PM
chuck,
The install looks great, nice job. Should be a plus when out this summer and putting back a few jello-shots. Are you thinking about going down to the Severn for the Blue Angels practice on the 22nd?
Treads is offline
Old 05-01-2007 | 12:58 PM
Strip Poker 388's Avatar
Rob
Pretty trick looking install
Strip Poker 388 is offline
Old 05-01-2007 | 03:03 PM
C_Spray's Avatar
Diamond Member #001
Treads - Can't make the Blue Angels (Hope that they are all recovering from the recent tragedy.)
88Formula223/Strip Poker - Thanks. Stainless is a real bear to work with, especially when you're trying to protect the pre-polished finish...
C_Spray is offline
Old 05-01-2007 | 08:40 PM
Thats looks great here is what I did with my flat screen.
Attached Thumbnails Flat Screen/DVD retrofit in 382-img_9881.jpg   Flat Screen/DVD retrofit in 382-img_9877.jpg   Flat Screen/DVD retrofit in 382-img_9878.jpg
formula 382 sr-1 is offline
powerquest 380
01-17-2006 09:42 AM
powerquest 380
Fountain
1
01-15-2006 06:12 PM
