312 w/ 496 HO's  ?s >
312 w/ 496 HO's ?s
312 w/ 496 HO's ?s
Old 05-15-2007 | 02:38 PM
Default 312 w/ 496 HO's ?s
Recently became interested in a 312 with 496 HO's. One of the few I've seen with k-planes. What kind of top speed and cruising speed can I expect with this boat? I've heard that the 312s had a porposing issue at cruising speeds, is this true? Anything else I should know about the 312?
jmeng is offline
Old 05-15-2007 | 03:34 PM
t500hps's Avatar
21 and 42 footers
I had one with 502 mags (nearly the same HP). Ran 70 everyday, 73 under good conditions. Serious tweeking will get a little more. The extra 10HP might get you one more mph. I never had a porpoise issue but I felt the boat ran flat. I think my props needed a little work to get the bow up but I corrected that by buying a bigger boat!!!!
t500hps is offline
Old 05-15-2007 | 04:13 PM
I was hoping for 73 any day and 75 - 76 under ideal conditions. I've read a few of your old threads, am I remembering right that your boat had some nicks on the props and in the bottom? Glad to hear the porposing might just be a rumor.
jmeng is offline
Old 05-15-2007 | 04:56 PM
t500hps's Avatar
21 and 42 footers
You are remembering correct. My motors were fresh but the bottom needed some minor work. Props were probably a little flat. A local had one just like mine that claimed he saw 75 once or twice.....I never did. (Mine did show 78 on the speedo ) With 425 HP and a good running surface/props the speeds you mentioned are probable.
You wouldn't buy a boat without a sea-trail now would you???
t500hps is offline
Old 05-15-2007 | 06:29 PM
Every 312 I have driven has run flat. I think the single step did not work the way they thought it would. The first 292 I drove pop the nose up and took off. But the 312 w/496`s would be my choice over the 502`s. I would give up the speed for the newer engines w/cwc.
selpel is offline
Old 05-16-2007 | 07:41 AM
Wouldn't even consider it, just trying to decide which boats are worth a plane ticket.
jmeng is offline
Old 05-16-2007 | 02:40 PM
What does 'runs flat' mean?
John T is offline
Old 05-16-2007 | 02:56 PM
88formula223's Avatar
NO WAKE ENFORCER
just as it sounds flat in the water, to get more speed the boat needs to get out of the water more
88formula223 is offline
Old 05-16-2007 | 05:44 PM
Charter Member #795
Had a 312 w/ 502's. 73 mph would be tops. Slight porpoise issue at mid range, but easily corrected w/ a little tab. Mine had K-planes. Good boat for the $ on the current market.
ontheh2o is offline
Dock Holiday
3
07-10-2020 06:23 AM
hvyhitter19
02-11-2006 08:50 AM
TEAMBAJA
11-18-2005 11:08 AM
Bajabuoy
4
03-14-2004 08:29 PM
Paul Perzyk
4
03-05-2003 09:39 PM
