Bad A$$ KAAMA 302
What year is it? Can something be welded to the busted drive? The housing cannot be found easily. The innards are readily available. I'd loose that teak swim platform too. If mine didn't alreay have a swimplatform on it, I wouldn't put one on.
Was not saying that you could not put a tripple under it just that you did not have to.
The advantages of a tripple is that you can run smaller tires, bearings, brakes and so on = cheaper parts but you need to buy more of them.
The disadvantages is that you have to pay for that extra axle at tolls, they don't turn as well as a dual axel.
My dual axel is sized so that if I blow out a tire/bearing I can run on just that one axel.
Put your best foot forward!
