help lost power >
help lost power
help lost power
Old 06-05-2007 | 07:53 PM
Default help lost power
Just replaced my intake gaskets and we lost power to the coil. then as we were searching out the answer we lost all power from the key back and keep blowing fuses for the switch. We replaced the cellenoid and have checked everything. it is wired exactly like the port motor. any suggestions?
it is a thunderbolt mercruiser ignition
twin242ls is offline
Old 06-06-2007 | 05:29 AM
Check The Emergency Tether switch, Seems to alot of those get pulled off accidently.
Reliant is offline
Old 06-06-2007 | 06:23 AM
Audiofn's Avatar
Charter Member #232
Good thought cuz we had that happen once when we were working on the race boat. Looked at everything then I went under the dash.....
The problem hear is he said that he has blown fueses. That would not blow any fuses....
Some place you put power to ground or wired something backwards.
Jon
Put your best foot forward!
Audiofn is offline
Old 06-06-2007 | 11:34 AM
Jon
Agreed. Better check and recheck that coil wiring. It's the only wiring you would have messed with so it's probably the problem.
ThirdBird is offline
chattviper
25
06-30-2008 04:59 PM
twin242ls
3
06-06-2007 05:44 AM
norton
29
11-29-2006 11:29 AM
jcimprover
3
08-28-2005 07:56 PM
DustinM
07-19-2005 09:02 PM
