Need HELP!!!! >
Need HELP!!!!
Need HELP!!!!
Old 06-29-2007 | 08:21 PM
86formula242ls's Avatar
Default Need HELP!!!!
started to drive, popped out of gear now won't go into gear. Just put in a new lower unit, could this be the upper unit? please help!
thanks!
86formula242ls is offline
Old 06-30-2007 | 09:09 AM
88formula223's Avatar
NO WAKE ENFORCER
post in the general help section to get a quicker response, not many people in this section on the weekend
88formula223 is offline
Old 07-02-2007 | 07:28 AM
Could be as simple as the shift coupler. Those little clips can be troublesome. Did you do the drive swap? If so, are you sure you got the shift cable clipped properly? It has to engage and then be clipped down to lock it.
ThirdBird is offline
