382 cabin door is really hard to open/close... >
Old 08-16-2007 | 06:29 PM
Default 382 cabin door is really hard to open/close...
I've greased the tracks and the teflon runners well but not much help. The boat is 2001 with 250 hours. Who else has had this problem and how did you fix it? I don't see anything anywhere that is interfering and it does not look easy to take the whole thing apart...thanks for any help.
jody165 is offline
Old 08-16-2007 | 06:54 PM
I use kitchen grade silicone spray. Works well, stays clean.
Cliff Dweller is offline
Old 08-16-2007 | 09:41 PM
Why wouldn't my white grease work well...?
jody165 is offline
Old 08-16-2007 | 10:17 PM
Silicone is a little slicker, but probably wont last as long as your lithium grease.
BTW, I had to start lubing my door in July and the boat was only 5 months old at that time. I asked the dealer about it and he said, " ya, ya gotta lube um".
I wonder if your guides need to be replaced, 250 hours? Na, they cant be worn out yet.
Also I was told not to cruise with the door open. That the pounding on the water might flex the bottom track. Could yours be off enough to allow the door to shift when open, making it bind up?
Mine is a 31 pc. not sure how different the doors are.
Old 08-17-2007 | 08:30 AM
C_Spray's Avatar
Diamond Member #001
When my 382 was brand new, I found a 10" sliver of fiberglass that had fallen into the track and was creating problems. It was really thin and hard to see... I've always had good luck by cleaning the tracks really, really well and using a small film of silicone grease. Clean is as important as lubed.
C_Spray is offline
Old 08-19-2007 | 05:29 PM
I cleaned it as good as I could, sprayed some wd-40 (which helped clean it) and it did make it a little easier. Still not very easy but better...
jody165 is offline
Old 08-20-2007 | 10:48 AM
axapowell's Avatar
Where To
Check that all of the guides are tight. Mine loosened up a little and it made it a little hard to slide. I tightened the guides, cleaned the tracks with NO lube and it is back to new again!
Dave
axapowell is offline
Old 08-21-2007 | 03:10 PM
freckles's Avatar
Try Armorall
freckles is offline
Old 08-21-2007 | 04:08 PM
Originally Posted by freckles
Try Armorall
I just heard this from Daryl in Formula customer service. Will reclean everything and apply Armorall....strange as it sounds. Will post the results. Thx.
jody165 is offline
noyzee
Baja
4
08-19-2008 12:04 PM
Chris Sunkin
Cigarette
1
11-27-2007 12:57 PM
Wild
Cigarette
5
10-05-2005 01:26 PM
Chris288
06-21-2005 12:52 PM
Bajaforce
Baja
0
01-08-2003 03:18 PM
