Termite formula 233 >
Termite formula 233
Termite formula 233
Old 03-06-2008 | 07:12 AM
I want to pass this on about ants in your boat, found out through being in the landscape business that ants will eat only rotted wood, they will NOT eat good wood only rotted wet soft wood so if you have ants you might have bigger problems elsewhere. Hope this helps
prosno is offline
Old 03-06-2008 | 10:53 AM
Nice progress on the old Bird, you've done a ton of work. It's cool to se how people's projects come along, keep posting.
How did you determine the height for the outboard bracket? How will you know if the engine sits too deep or too high?
Are you going to paint it too or use it as more of a "beater"?
ThirdBird is offline
Old 03-06-2008 | 07:36 PM
Default No more bugs
Hi Tbird, thanks for the kind words.
The bracket came with a large clear plastic template. On the template there are directions. Deadrise, transom angle and shaft length are the variables used for correct placement. Its was easy. I wen the extra 2 miles. Once I marked my locations I used a 1 1/2 hole saw. This left me with 12 nice holes in my transom. I then filled the holes with epoxy/cab. Waited 48 hours and then drilled 3/4 inch holes. This will pretty much gaurantee no water gets into my new core.
Some say its anal, but I say its worth it after seeing the damage water intrusion can do.
I plan on painted it. Once everything is sorted out, Im going to give it a sweet awl grip paint job.
You have a formula?
mbeyra is offline
Old 03-06-2008 | 07:38 PM
Default No wood
Prosno:
All wood was removed. All that was left was a bare hull. Thanks for the info though.
mbeyra is offline
Old 03-07-2008 | 06:18 AM
Good luck project boats can be rewarding and fun, keep posting pics
prosno is offline
Old 03-07-2008 | 06:21 AM
Audiofn's Avatar
Charter Member #232
Wow what a project and it acually looks really cool from the pictures. Keep them coming and let us know how it goes.
Jon
Put your best foot forward!
Audiofn is offline
Old 03-07-2008 | 11:12 AM
You have a formula?
Pretty cool idea, the cooring and epoxying.
Yes, I have an '89 311.
I've always liked the older 233s, rugged looking hulls.
Old 03-07-2008 | 11:14 AM
Originally Posted by Audiofn
How about "Buggin Out"
Great name, you gotta use that one!!!!
Boat names should always have story particular to the boat or the owner.
Captain Dangerous
Classic Offshore
20
08-22-2012 04:53 PM
08-01-2008 05:24 AM
Captain Dangerous
Do It Yourself, Boating on a Budget
3
05-23-2008 04:26 PM
Captain Dangerous
06-14-2007 01:25 PM
DelawareRiverRunner
09-09-2005 02:40 PM
