Another silent thunder thread >
Old 09-15-2007 | 01:33 PM
freddan's Avatar
Default Another silent thunder thread
Hi!
Has anyone ever tried to take the silent thunderplatform apart? Splitting the two glassed halves apart? Im about to give it a go but it seems lika VERY tough job, it seems that formula used alot of that green resin to glue the two halves together.
Heres what i´ve done sofar; I removed the glassed wood in the back of the platform because it was in really bad shape.
Now Im trying to split the platform apart but its a timeconsuming work.
The reason why im trying to do this is that I want to remove the grabhandles (and some do some other modifications) and give the platform some new paint.
My boat is a 292 SR1 89' with ocean #2 Imron paint.
thanks!
Attached Thumbnails Another silent thunder thread-tn_bild339.jpg   Another silent thunder thread-tn_bild340.jpg
freddan is offline
Old 10-05-2007 | 09:50 AM
I have a 292 and Bald Knob took the box off for me and put flaps on the back to the boat to hold water out.. Its a bit louder and better air flow.. Its worth the $150
TheKoz96 is offline
Old 10-05-2007 | 11:28 AM
5PMSMWHR's Avatar
Why put it back on at all? I've got a 353 version takin' up too much room in my garage, I'm about to take the chainsaw to it.
5PMSMWHR is offline
Old 10-05-2007 | 11:52 AM
No fair with the Fastech...you still get to keep a swim platform when you remove the "box".
On our older SR1s, the "silent thunder" is the whole platform, not just a box underneath.
Freddan, I think at least one other member just rebuilt the platform altogether. Hopefully they'll chime in with their experience. Otherwise, it sounds like maybe a Roto-Zip might be the best bet for just cutting the seam?
handfulz28 is offline
Old 10-05-2007 | 11:56 AM
My 92's not a Fastech, but mine was a bolt on, now it's a garage ornament.
h2oboy is offline
Old 10-05-2007 | 02:34 PM
LV's Avatar
LV
I have taken one off before, it pretty much sucked, it was an 89 as well.
LV is offline
Old 10-06-2007 | 09:55 AM
5PMSMWHR's Avatar
Ahhh, I wasn't aware that it was integrated with the platform. In that case that job must suck.
5PMSMWHR is offline
Old 10-23-2007 | 02:47 AM
hi freddan
Originally Posted by freddan
Hi!
thanks!
now im here too,another good forum on the net nice too bee whit formula
maelstrom is offline
Old 10-23-2007 | 08:43 AM
There is a lot of information on silent thunder exhaust over on speedwake.com. Check it out.
zdek is offline
Old 10-23-2007 | 11:09 AM
That could be a real chore to split the platform open. As you've noticed, the upper and lower halves are rivited through the rub rail. It's probably also glued like the main hull-to-deck joint. Chances are, if it's glued, you'll never get it apart without destroying it.
Why do you want to split it open?
ThirdBird is offline
