First Run ....Not So Good >
Old 05-11-2009 | 11:24 PM
  #101
I haven't read your whole thread but just curious if the person doing your engine work is a marine engine guy? There are more differences between marine and automotive engines than a lot of people know. Lots of variables, gaskets, valves, cam, bearing clearances, piston to wall clearances, cam choices, how much timing. All these things add up to making marine power much differently than strip power. An engine that works well on the strip might not last too long in a boat.
Sunshadow is offline
Old 05-29-2009 | 01:18 PM
  #102
**UPDATE**
Well after some debating I went ahead and bought new heads. Went with 308cc Darts. The block is done and bought one new piston. I talked to Precision Power today and he going to get on them right away. We are also going to do a cam change as well. I hope to gain some power and have a turn key boat!!! i will post results after the build!
Car Biz is offline
Old 05-29-2009 | 03:26 PM
  #103
masi242's Avatar
Good luck CB you could use a trouble free summer
masi242 is offline
Old 05-29-2009 | 04:17 PM
  #104
Thanks Bro!!! Considering i have had it for almost 2 yrs and only put 25 hrs on it i need to have some fun
Car Biz is offline
Old 05-29-2009 | 04:27 PM
  #105
Damn boats!!! Hope your luck turn around w/ it.
JayFan is offline
Old 08-05-2009 | 07:53 AM
  #106
***UPDATE***
Dynoed one yesterday all in all good. 454 HP and 514 TQ this was with manifolds @34 degrees. At full throttle the motor was plently fat BUT Ben found that at part throttle it would go into 14.8-15.0 AF. Prolly why the motor came apart last time. he called me and said he ended up with 84 squared on the jets. i hope to be testing on fri night. I will post the dyno sheet when i get it
Car Biz is offline
Old 08-12-2009 | 09:27 AM
  #107
Well i think the drama is FINALLY over. Test run last night other than fine tuning the idle the boat ran good. ALOT of little things had to be done but i think she should be trouble free!!!
Car Biz is offline
Old 08-14-2009 | 12:09 PM
  #108
HERE IS THE "NEW' DYNO NUMBERS.
Only change was the cam and heads dynoed with manifolds not headers.
Cam is a Comp Cam # CB XM 270H-12
Heads are the Summit BBC 308CC
Click the pic it will get bigger to read!
Attached Thumbnails First Run ....Not So Good-dyno-ppo-001.jpg   First Run ....Not So Good-dyno-ppo-002.jpg
Car Biz is offline
Old 08-14-2009 | 11:12 PM
  #109
88formula223's Avatar
NO WAKE ENFORCER
congrats biz
88formula223 is offline
Old 08-19-2009 | 03:50 PM
  #110
Rambunctious's Avatar
awesome Jeremy
get some hours on that puppy
buddies are wanting a "guys boat day" soon
so maybe we can hook up in Grand Haven
Ramb
Rambunctious is offline
Velocity Tom
04-29-2006 08:18 PM
ActiveThunder
Active Thunder
22
12-25-2004 06:10 AM
StrikinLightnin
08-27-2002 08:38 PM
