Prop Question (HP 600's) >
Old 12-11-2007 | 02:14 PM
Default Prop Question (HP 600's)
We have a 382 with 600's and Stelling boxes and want to get a spare set of props. What are the best props for highest top end for this setup?
PremierPOWER is offline
Old 12-11-2007 | 03:21 PM
Charter Member #415
Will check my notes tomorrow for pitch,but we like Maximas,non labbed. I believe 28's ,but I will confirm. Hope the non labbed comment doesn't ruffle any feathers,but honestly,we have had better luck with stock props than Merc Racing labbed. Of course,Throttle Up or B-Blades labbed may be better,my comparison is only between Merc stock and Merc Racing Labbed.
Magicfloat is offline
Old 12-12-2007 | 05:56 AM
Magifloat - I have a 96 382, garage queen with 600's - 1.50 and run a 28 Bravo 1 - Sounds like you like the five blades - do you have speed vs rpm for your set up ? No way this baot will every be fast so I'm happy with good slip numbers and good mid range -
James is offline
Old 12-12-2007 | 09:20 AM
Charter Member #415
Bad info from last night,the non-labbed comment is for Bravo I's,not Maximas. Our testing shows Maximas benefit fro labbing,but in most cases labbing increases slip on Bravo 1's. Maximas'have enough additional blade area to not have as much spip problem. We use 29 lab Maximas on 382/600's.
Old 12-14-2007 | 06:11 AM
Fastech bottom or old style - what is you slip with Maximus
James is offline
Old 12-14-2007 | 10:28 AM
Charter Member #415
It's a Fastech. With Labbed Bravo 1's,81 at 5100,with lab Maximas,86 @5150.
Old 12-14-2007 | 08:01 PM
Majicfloat,
Thanks for the info .... glad to see that you are back!!!!
Old 12-16-2007 | 05:39 AM
I order a set of Maximus from BBlade - I have 540's with Weiand 250 blower 3 lbs boost is 645 Hp - Boat won't go fast but it does look good getting there -
James is offline
Old 12-30-2007 | 11:01 AM
WAGS382's Avatar
I am not impressed with labbed b1's on the 382 fastech, way to much slip.
Jeff
WAGS382 is offline
bimmerboy318
Prop Talk
7
07-12-2008 09:46 AM
Magicfloat
06-22-2008 04:22 PM
ThoroughHustler
Active Thunder
2
01-09-2007 06:26 PM
SUREPOWER
Fountain
17
08-14-2006 09:32 AM
FlyFast
1
08-06-2004 10:22 AM
