Formula fastech questions
Hello, Im looking at a 97 312 fastech. Has anyone had any hull issues with them? On the bow above the front bulkhead there is a spot a couple inches inside the bow rail where the gel coat is spider cracked toward the center of the boat directly above the front bulkhead. Is this common and does it get worse? Second in the cabin under the seats there are a couple of places on the hull where what looks to be a 12"x8" rectangle spot that was repaired after it left the factory. Any info on this would be great. Thanks alot.
Call the TAG (Technical Assistance Group) at Formula and see if they know anything about the boat in question. They keep records of any dealer repairs or known damage on all their boats. All you need is the hull ID number.
260.724.1412
260.724.1412
Not to be outdone, but for close to the $ you are talking about I have a 2000 312 without a scratch on it. 3 years newer and I promise not a single defect. The ad is in the classified section.
Also, about the 312 versus 353, I currently own both and each has their own benefits.
Not a "hands down" difference.
