Rear Lettering >
Rear Lettering
Rear Lettering
Old 04-12-2008 | 09:27 PM
Default Rear Lettering
My boat is USCG Documented, and I need to get the lettering installed. I found a graphic shop to do the job, but he is concerned on installing on the non smooth surface below the swim platform. The area has three small 2" steps on it.
Can anyone with a 382 send me some photos of how they installed their letters? The graphic guy wants to see a pic of a boat that has letters on that surface. (He wanted to put the letters on top of the exhaust ports) I told him that they would be under water and could not be seen.
Any help is appreciated.
My boat name is "Liquidated Damages"
Eunice, LA
Mackattack is offline
Old 04-12-2008 | 09:43 PM
BL6
This is a 353, but maybe it helps. Our home port is on the right side, under crome Formula name. (we are not documented)
BL6 is offline
Old 04-12-2008 | 10:51 PM
I don't see why the 3 2" steps would cause any problems for your graphic guy. Worst case, he'll need to use a little heat to make the vinyl conform, but other than that, should be no problem.
Post a picture after it's done.
Name That Boat.com is offline
Old 04-13-2008 | 04:14 AM
RedDog382's Avatar
I would check with Dukenrock to see if he can send you a shot of his "Twisted Pair". Nicest graphics I've seen yet ...
RedDog382 is offline
Old 04-13-2008 | 07:59 AM
I installed graphics on a 292 last summer - in the water at the dock. Took a little extra time, but had no troubles. Like I said, tell him to be prepared to use a little heat to conform to the steps and you'll be fine.
Old 04-13-2008 | 10:48 AM
The lettering is Coast Guard approved...I've been stopped twice and they had no issue with the lettering size. These are vinyl letters that I purchased at West Marine. I'm probably going to be changing the lettering this year to a solid color.
Attached Thumbnails Rear Lettering-382casino-005-standard-e-mail-view.jpg   Rear Lettering-382-gps-006-standard-e-mail-view.jpg
kjm5125 is offline
Old 04-13-2008 | 12:09 PM
:d
formula 382 sr-1 is offline
Old 04-13-2008 | 04:30 PM
C_Spray's Avatar
Diamond Member #001
Put these on myself - No sweat.
C_Spray is offline
Old 04-13-2008 | 07:43 PM
5PMSMWHR's Avatar
'02 353 same graphics as BL6
5PMSMWHR is offline
Wild
09-11-2006 02:30 PM
Elite Marine
Pantera
5
04-19-2006 07:14 PM
MarkSmith
06-30-2005 09:23 PM
Semper Fi
03-30-2005 09:29 PM
NASDBOY
01-21-2002 10:32 AM
