1986 Formula Tach. Reading slow... >
Old 02-28-2002 | 01:38 PM
boatinbill's Avatar
Registered User
On a similar note, my Gaffrig tach jumps around a bit (a few hundred RPM) at about 3000RPM, then settles back down as the rpms rise. It does make me wonder if I am reading high or accurate at full throtle though. I have talked to the selling marina, not very helpful (they are also no longer a Formula dealer I should add, good thing).
Gaffrig told me it may be noise in the wiring, how can I tell? I also do not have access to a second tach to verify the reading, hate to buy one just for testing this one.
Any suggestion before I purchase a new tach?
boatinbill is offline
Old 02-28-2002 | 05:35 PM
JON242
That tach should be adjustable. I have a Medallion tach in my 86 242. It was off by a few hundred RPM and I was able to adjust it. There should be a screw on the back, maybe covered by a rubber plug I can't remember. Get a digital tach, hook it up to the motor and adjust your guage to match the digital. Real easy.
Old 02-28-2002 | 11:49 PM
Audiofn's Avatar
Charter Member #232
If the tack is jumping Gaffrig makes a filter that may work. You can put it in line and it should be good.
Jon
Audiofn is offline
DareDevil
Swap Shop
9
08-07-2008 11:09 AM
Biggus
09-24-2007 09:20 PM
Alanseattle
02-27-2007 03:05 PM
Builder Bob
04-21-2006 07:36 AM
Smokinlegend
11-30-2004 07:33 AM
