deck ripple 402 >
deck ripple 402
deck ripple 402
Old 07-04-2008 | 03:04 AM
Default deck ripple 402
Hi all, I'm looking at a 402, early 80's. At the front of the deck, there is a concave ripple in the glass. It's noticeable. The owner tells me this is a common problem on the 402's. I've never seen one before. Is this indeed common, and if so, what is the fix?
scarabnewbie is offline
Old 07-04-2008 | 07:39 AM
is it above any walls that are in there.. Wow 311 to 402, big jump.
BOATMAN302 is offline
Old 07-04-2008 | 12:31 PM
It might be above the very front wall. I haven't seen it in person. I was thinking the same thing, maybe the wall had broken, or something like that.-
Old 07-07-2008 | 07:44 AM
wantsa311's Avatar
Most 311's have a crack or ripple on the deck, right above the front wall of the head enclosure. I bet there is something similar with the boat you are looking at.
wantsa311 is offline
Old 07-07-2008 | 09:31 PM
My 402 has a slight concave dip in the deck on the port side where there is nothing there to support it from underneath. I dont think its anything to lose sleep over.
On the 402, there is a section of wall that supports the deck right before the v berth, then after the vberth there is a small access door that opens to access the dock lights, cleat, etc.
One things for sure, the 402's ride like a caddy.
MILD THUNDER is offline
MILD THUNDER
10-12-2007 03:41 PM
