Steering wheel upgrade help >
Old 07-14-2008 | 01:51 PM
Default Steering wheel upgrade help
I have a '92 303 SR-1 with the original wheel using a 7-hole mounting configuration. Can someone please tell me what is involved to change out to a newer style wheel utilizing 6-holes....? Is there an adapter available? Will the old wheel just pull right off once the 7-hex bolts are removed?
Thanks!
BowenCT is offline
Old 07-14-2008 | 04:39 PM
rjr
Where are you in CT. I can probably help a fellow OSO'er if there is nothing commercially available.
rjr is offline
Old 07-14-2008 | 04:59 PM
rjr,
I am in New Milford, the boat is on Candlewood. Do you have machining capabilities? Where are you located?
Thanks,
MB
BowenCT is offline
Old 07-15-2008 | 07:26 AM
rjr
I am in Cheshire. Making an adapter shouldn't be a problem but check with the steering wheel mfg first to see if an adapter is available.
email me at [email protected]
rjr is offline
Old 07-15-2008 | 11:20 AM
RedDog382's Avatar
Thanks!
Good luck with this part. Even with a wheel puller and a BFH, I could never get the hub off my '89 311 ...
RedDog382 is offline
Old 07-15-2008 | 12:15 PM
rjr
One thought on the adapter. If the bolt hole circles are not pretty far apart the heads of the bolts, and maybe the threads will overlap
rjr is offline
Old 07-15-2008 | 12:18 PM
rjr
Are you trying to take the hub off? I was thinking that you wanted to bolt the adapter to the hub and the new wheel to the adapter.
It would be easier to make an adapter if the hub were here.
rjr is offline
Old 07-15-2008 | 10:11 PM
Elite Marine's Avatar
If we can help, let us know. We can get anything in the Livorsi line for steering wheels and hubs if needed.
[email protected]
Kirk
Elite Marine is offline
Slick02
21
12-21-2006 12:45 PM
Sonny Spectre 30
22
02-16-2006 04:35 PM
b717200
37
05-23-2005 10:44 PM
Sydwayz
07-25-2004 08:49 PM
RMPRam
Cigarette
5
03-26-2002 01:42 PM
