Prop question on a 242 ss 454 330 hp >
Old 07-31-2008 | 07:01 AM
Default Prop question on a 242 ss 454 330 hp
have a 242 SS 1988 with a standard 454 330 HP 1997
GenV. The prop is a Mirage Pluss 17, I know the prop
is to "small"
Ex.:
3200 rpm my speed is 28 miles
My rpm is much higer then it is supposed to be, but I have
never taken it higer then 4500 then I get aprox 42-43 miles.
I have a lot more throttle to give but, I havent let the engine
gone over the 4500 rpm.
I am going to buy a new propp, but I am not sure what kind of
prop either mirage P19, mirage P21 or bravo1 4 blade 20
My normal boating is 2-4 people some gear, I am not to stressed by top speed, but of course everybody want his boat
to go as fast as possible.
I would like it not to be to slow to plane, and have a good midrange preformance.
So what should I go for??
Monaco20 is offline
Old 07-31-2008 | 08:51 AM
Before you buy one try a 21 Mirage i would then go to a 23 Mirage. After that try a 22 4 blade bravo one. I had a 272 that i ended with 23 mirage.
Car Biz is offline
Old 07-31-2008 | 12:34 PM
I still run a 23P Mirage 3 blade now, reasonably good performance even when I had the 454mag in it..
R
Blue242 is offline
Old 07-31-2008 | 01:47 PM
Guys thank for your replies
Remember I have 7,4 l wit 330 hp and not a Magnum
I am afraied that more then 21p could be to much?
Monaco20 is offline
Old 07-31-2008 | 02:28 PM
Nope 23 should be fine.
Car Biz is offline
Old 07-31-2008 | 06:51 PM
mopower's Avatar
Toxic FORMULA
A friend has a 242/330 combo and runs a 21 Mirage and gets 53/54 mph. I'd also try a 22 Bravo. Will definitely increase midrange speed. Another friend had a 242/502 Mag , went from a 23 Mirage to a 24 Bravo an picked up 5 mph at 3000 rpms
mopower is offline
Old 08-01-2008 | 05:26 AM
23 will be too much for the 330. Stick with the 21, you'll be happier.
ThirdBird is offline
Old 08-01-2008 | 08:05 AM
thanks_don's Avatar
Thirdbirds correct .... I had a 90' 242LS 330 b1 1.50 gears with a 21p ss mirage, hole, midrange, topspeed 51-52 good luck.
thanks_don is offline
Old 08-01-2008 | 03:05 PM
Hi Guys
Thanks a lot for all the replies, I am leaning to a mirage 21
I will tell you how it went when I have tested the prop
Monaco20 is offline
Old 08-01-2008 | 04:39 PM
Talking
Hey, I have a '89 242 SS with a stock 454ci 330hp package and I upgraded from a 19 to a 23 pitch and I am very happy with the result. 56.7mph @4600rpm on gps.
Oh by the way, I'm new to OSO and this site is AWESOME!
My1stFormula is offline
