353 Boat & Trailer Combined Weight >
Old 05-13-2013 | 08:50 PM
Old post but I was wondering if anyone else has had their 353 across the scales. Current tow vehicle is a 2002 7.3L Excursion, and I don't really want to sell it. Would be making pretty regular trips from Detroit area to Northern Michigan, Torch Lake an Elk Rapids (4.5 hours).
D2HP is offline
Old 05-14-2013 | 07:39 AM
I have had my Baja 342 on one. similar boats.
that and my 2500 was right at 20k.
mittens is offline
Old 05-14-2013 | 12:35 PM
There are things that can improve the X's towing by reducing the spring wrap of the rear springs. If controlling the boat with the X is a problem, I can direct you to this improvements.
Chart is offline
Old 05-14-2013 | 04:50 PM
MrMagloo's Avatar
Originally Posted by sleek1
I weighed mine on a truck scale hitched to my F250. I came in at 11,400 lbs with a triple axle aluminum trailer and aprox. 50 gallons of fuel. My tongue weight at the time was only around 240 lbs (if I remember correctly). I have since moved the boat forward as to get 650 lbs tongue weight.
Holy Cow - 250Lbs TW on a 11, 400 load. Jeez, you're lucky that thing didn't go for a ride on you. Even 650 is on the low side.
MrMagloo is offline
Old 05-15-2013 | 08:26 AM
Found my Cat scale ticket.
Boat/Trailer with less then 1/2 tank was 10,680 LBS
Truck was 8,680LBS
total 19,360Lbs
mittens is offline
Old 05-15-2013 | 10:06 AM
Mittens do u have a steal trailer or Al. That weight would work with the Excursion.
D2HP is offline
Old 05-15-2013 | 10:10 AM
Aluminum. tripple axle.
mittens is offline
Old 05-15-2013 | 10:25 AM
VoodooRob's Avatar
I have an 01 Excursion 7.3 and towed my 353 from Wisconsin to Cleveland 2 weeks ago. Before the tow I added Firestone airbags and a Hellwig rear sway bar. Also installed poly bushings in spring eyes/sway bars front and back and slotted brake rotors with new pads. This really helped the truck stabilize and tow much better than stock. I still get slight wander with or without load, next will be some highway friendly tires to replace the lugs on now. The Excursion has a sloppy road manner from the factory, springs are too soft and front end parts wear fast. With the mods I did and the 353 behind the truck that's as much as I would want to put behind it.
VoodooRob is offline
Old 05-15-2013 | 12:42 PM
VooDoo do u have any idea what your boat and trailer weigh in at. I already have a set of airlift bags on the ex, rear sway bar, and some nitto 285 e-rated tires.
D2HP is offline
Old 05-17-2013 | 11:12 AM
Anyone else been on the scales? The one brochure I have says the boats around 9500lbs. Would an early 2000s be lighter?
D2HP is offline
