Best exhaust for Formula w/TRS >
Old 03-18-2009 | 05:28 PM
jeff32's Avatar
I also had a 1986 f 35-7, and I have left 1 set of stainless marine exhaust that I never even tried... did they have stainless marine exhaust back in these days or they were newer exhaust ? maybe I could use them now????
jeff32 is offline
Old 03-18-2009 | 07:45 PM
Originally Posted by jeff32
do you have a pictures of your current exhaust? I just want to see if your ''engine destroyer'' exhaust looks loke mine????
Also thinking switching for newer exhaust, for the affordable way...
Jeff, I don't have any pics to post. They are the stock cast manifolds used on the first 420's. They have a rubber gasket between the manifold and riser. The tails are stainless and also have gaskets at the flange joint. Water flows thru gaskets instead of using hoses like the later Gils. The rubber gasket is the problem, just not a good design. I suppose if they were changed every year, they'd be fine.
When I bought the boat, the damage was already done. Plus the water ports between the tail flange and risers were clogged with scale from 20 years of no maint. Gota have water flow thru the exhaust or the engines over heat. If you have the pre gils, change the gaskets. you can still buy them if you get a part # and google it. If you need it, I can get the part # for you.
Cold Sweat is offline
Old 03-18-2009 | 07:53 PM
Originally Posted by poiuy10
Coldsweat,
I basically did what you are doing, I went with the CMI's. here is my add on another site, to see the application.
https://www.boatcrazy.com/search/details.php?id=468
see what you think, the original owner re-drilled the thru-transom higher as you can see its above the taco rail in the back. Good Luck !
Those are sweet, I guess they make them for TRS. Nice clean installation. Might be over my budgit, this boat is killin me. But I will have two new engines when I'm done. Thanks all...
Old 03-22-2009 | 04:38 PM
Biggus's Avatar
If I were in your shoes, I'd buy a set of Stainless Marine manifolds/pipes. 5 year warranty. You can't go wrong with Stainless Marine, they make great power and last forever.
Kurt
Biggus is offline
greencard
01-28-2009 05:44 PM
spazboz
Do It Yourself, Boating on a Budget
4
06-08-2008 08:26 AM
saulesses
06-12-2007 08:52 AM
RNH
07-14-2003 12:39 PM
XCAV8
1
06-08-2003 05:07 PM
