-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Mufflers on a 382 (https://www.offshoreonly.com/forums/formula/205779-mufflers-382-a.html)
dave krehbiel 03-29-2009 10:02 AM
Mufflers on a 382
Well I finally did it and traded my 312 for a 382 and now have questions since I left the dealership. It has external mufflers and captains call. Is there a reason to have both? I will be boating on a local lake and the Ozarks, and think I could do without the mufflers. It also has sea strainers and I am not familiar with there operation, is there maintinance to them?
ur2slow 03-29-2009 10:09 AM
congrats on the new boat!! Post some pics
dave krehbiel 03-29-2009 10:17 AM
I new that was coming, I will as soon as I can. I am at work today and don't have access to my pics. Maybe tomorrow, and thanks I think we will like it.
Magicfloat 03-29-2009 01:08 PM
Formula has always wanted to be a good citizen and not build loud boats,hence the mufflers with CC. But it is a bit of overkill for some.If local laws permit it,just replace the mufflers with straight thru tips from an online vendor and sell the mufflers on E-bay. You can also cut the baffles out of the mufflers with a die grinder,but it is a big job and may discolor the finish. Most of our customers just buy new tips.
dave krehbiel 03-29-2009 01:25 PM
Thanks Magic, since I haven't even had it on the water yet I'll see how I like it the way it is for now. I think I,d like to here those 500's,but my wife may differ.
Magicfloat 03-29-2009 01:51 PM
Forgot to mention that the 500's have a "speed switch" that opens the CC at about 2800 rpm,so if you replace the tips,you will be loud above that rpm and cannot close the diverters even if you want to. Just another thing to consider.
dave krehbiel 03-29-2009 05:39 PM
4 Attachment(s)
heres some pictures.
I had my boat on the water for the first time today and everything went well but one red light. I don't know if the two red lights next to the tachs in these picures are stock and I am not sure what they are for, but the port one comes on at about 3000 rpms and stays on untill it drops below again. All the fluid levels are good, temp and oil preasures are good. The only thing I can think of is that they are rpm red line warnings and this one is not set right. Does anyone else have these and can help me out.
PhantomChaos 03-31-2009 02:13 AM
In the ocean (swells) the flappers help with water not going up the pipes!
dave krehbiel 04-01-2009 07:28 PM
I won't ever have this on the Ocean but the water at the Ozarks is probably about as bad so I think I will leave it as is for a while.
C_Spray 04-06-2009 08:00 AM
Your sea strainers should have clear lids. No routine maintenance required other than to check if there's any crap in them. A blade or two fo grass will eventually be ground up; no harm. but a good-sized chunk of plastic might restrict the water flow. Next time you're in the water, but before you start the engines and get them hot, practice opening them up and putting them back. You'll be glad that you did if you ever have to do it for real and the engines are roasting hot. They're down deep....
dave krehbiel 04-06-2009 10:16 AM
Thanks, if its what I think they are, they are in the bottom of the bilge in front of the motors and are all brass with wing nuts to open them up, no clear cover though. I can see it would be nice if they were clear, I might have to change that.
fossil fuel 04-06-2009 08:24 PM
Nort, have you had your flappers open again...all that water especially in the swell...sheez
C_Spray 04-07-2009 10:24 AM
2 Attachment(s)
Need a picture. That sounds more like a generator or AC strainer. Here's what I have. The black one on the left is bronze, just powder-coated, and is for the genny. The two stainless/clear ones with shutuff valves are for the engines.
<Edit> The second photo shows the (replumbed) strainer for the genny. I replaced the chintzy wingnuts with thumbscrews from McMaster-Carr..
dave krehbiel 04-07-2009 02:04 PM
Thanks for the info. Nice clean bilge, the gen is out of mine right now and I am going to clean it all up. Did you put the diamond plating in your's, I may do something like that in mine.
C_Spray 04-07-2009 05:06 PM
The full story on that bilge is here. It was "a bit of a project"...
