242 stereo upgrade >
242 stereo upgrade
242 stereo upgrade
Old 03-25-2002 | 01:06 PM
jrocket's Avatar
Default 242 stereo upgrade
Figure someone has a good idea on where to place amp, speakers etc. without comprimising space. Any good recomendations on types of disk players apreciated also, or better yet which one NOT to buy!
jrocket
jrocket is offline
Old 03-25-2002 | 09:58 PM
Audiofn's Avatar
Charter Member #232
I think that Clarion is your best bet in your boat due to Moisture reasons. Ams and such need to be in a dry area. If you choose good quality Marine speakers you will be ok with any water that may get on them. I like Babbs for most aplications
Jon
Audiofn is offline
Old 03-26-2002 | 09:43 AM
jrocket's Avatar
Does Clarion have the anti skip in check? My deck is mounted in the cabin so hopefully I want have any real moisture problems. Any suggetions on where to put a amp?
jrocket is offline
Old 03-26-2002 | 10:14 AM
I have a 242LS too- I mounted the amp just aft of the sliding plexiglass door on the inboard side of the port sidewall. That is about as close as you can get to the battery and/or switches (important!). It is relatively easy to wire forward to the port mounted galley where the head unit is, as well as the speakers mounted in the face of the aft bench seat.
jafo is offline
Old 03-26-2002 | 11:53 AM
jrocket's Avatar
Thanks jafo, are the speakers you using in the aft bench seat marine type or standard? Do marine speakers hold up to the higher watts?
jrocket is offline
Old 03-26-2002 | 07:01 PM
jrocket- I'm using marine speakers throughout. Quality marine speakers will handle what you can throw at them (within reason). Don't go cheap with speakers- you get what you pay for. AudioFn is the guy to talk to about this- I got my Clarion sub, and 6x9 & 5 1/4" Babbs from him. The quality of sound from these speakers is beautiful regardless of the type of music you listen to. Babbs are pricey but.........
Jim
jafo is offline
Old 03-27-2002 | 12:18 AM
Audiofn's Avatar
Charter Member #232
Jafo has it pretty well said. I like the Babbs for what I consider Entry level speakers. They are totally water proof. Some do not like the look of the grill but I think they look fine. The sound is unreal and they do not require a lot of power to run loud and clean. They will handle a good amount of power if you want to toss lots at them. If you have a unlimited budget then go with the Allumapros and watch out. But the price will be MUCH higher then the Babbs.
Jafo I am glad you like the stuff you have.
Audiofn is offline
Old 03-30-2002 | 07:05 PM
chavvez's Avatar
I mounted my Alpine amp inside the cabinet with the stereo. I mounted it to the wall which divides the cockpit and the cabin. Works pretty well and easy to wire.
chavvez is offline
Old 04-01-2002 | 11:01 AM
jrocket's Avatar
Thanks for all the Ideas! Knew I could find a good answer here
jrocket is offline
Liquid Therapy
South Central US
3
05-04-2008 12:13 AM
FinnBird
03-14-2007 05:00 PM
quadracr
11-26-2006 06:12 PM
Dave98
Powerquest
3
01-03-2005 12:26 PM
toolman
10-24-2004 07:26 AM
