Group 31 battery tray on a 2002 353? >
Old 05-23-2009 | 10:53 AM
5PMSMWHR's Avatar
Default Group 31 battery tray on a 2002 353?
353 with 500 EFIs, Formula customer service says it should be running a 24M7 starting battery and an 1131XMF on the other side. Prior owner had two 27 series deep cycle batteries in it. Question is, where to get a group 31 battery tray? The battery length is 12 3/4 inches on the 31 as opposed to 12 inches on a group 27. Any help or guidance would be appreciated, thanks
5PMSMWHR is offline
Old 05-23-2009 | 01:51 PM
Charter Member #415
In checking around,a Group 31 is hard to find. Formula has them of course,available thru most Formula dealers. It is Formula part # 4216.If you don't have a dealer,I will be glad to drop ship you one. Robert
Magicfloat is offline
Old 05-23-2009 | 01:57 PM
Charter Member #415
Formula's 31 box is from Gil Marine,don't know if Gil sells direct or not,it is now part of Corsa.
Old 05-23-2009 | 07:18 PM
Here's a thought for you. Do a pair of group 27 dual purpose batteries, did this on the last Fountain and I'm thinking this one is going to the same program if they don't come up like they should. Worked out well for me the last time, but then you know I'm not into the overdone electronic blingerizing.
Looks to be a lot of box options thru the aftermarket marine biggies for the 31 Optimas but slim pickings for reg 31's.
I'm beginning to think you Formula guys think you have Hybrids. 31's won't make it run any better! And you'll never drowned out Twins and Axa in a raft up anyways.
RaggedEdge is offline
Old 05-23-2009 | 08:16 PM
5PMSMWHR's Avatar
ROBERT,
You're right they are hard to come by for 31s. Let me know what you need to drop ship one to me, I can PM you CC info once I know the $$, thanks
5PMSMWHR is offline
Old 05-23-2009 | 09:17 PM
Charter Member #415
I don't do PMs.Email me @ [email protected] or just call me anytime 24/7 @205-221-3072.Just need a ship address and cc # Robert
Old 05-25-2009 | 01:16 PM
t500hps's Avatar
21 and 42 footers
I took my old ones in and they hooked me up with a group 27, and a group 29.....fit the trays too!!
t500hps is offline
Old 05-26-2009 | 07:13 AM
C_Spray's Avatar
Diamond Member #001
I have the Gil bracket(s) in my 382. I extended the port side one to fit two house batteries, though. (See before/after photos.) They are a nice cast aluminum piece, but I strongly recommend putting heli-coils in the bases where the the hold-down studs crew in. If you don't, the aluminum and stainless will react with each other over time (galvanic corrosion) and you will have a VERY hard time removing the stud to change batteries.
Attached Thumbnails Group 31 battery tray on a 2002 353?-batterystbd20040224-large-.jpg   Group 31 battery tray on a 2002 353?-batteriesstbd20080403-large-.jpeg   Group 31 battery tray on a 2002 353?-bilgeportrear20080325-large-.jpg
C_Spray is offline
