Captian's Call >
Captian's Call
Captian's Call
Old 08-02-2009 | 03:17 PM
Default Captian's Call
out with my 03 353 yesterday , when at one point shut ehaust switch off and on of the motors was still loud , not as loud as open but also not quiet, any idea's what might be wrong never happened before....
jwheels629 is offline
Old 08-02-2009 | 05:28 PM
sleek1's Avatar
sounds like the mechanical "diverter" is stuck between thru and hub exhaust position. Could be a solenoid or relay?
sleek1 is offline
Old 08-05-2009 | 11:31 AM
Weak solenoid.
ThirdBird is offline
Old 08-09-2009 | 06:46 AM
Registered User
I agree with others, sounds like you have a sticking solenoid on the exhaust diverter pipe. You can go to www.boatstoreonline.com and order the part direct if you want to replace it yourself they are usually either the 3 or 4 wire type.
My experience is, one it starts sticking, it will eventually fail completely before too long.
redwenvy is offline
Old 08-09-2009 | 08:52 AM
rhsj2006's Avatar
I bought my 2003 292 with 130 hours, and the previous owner must have had a real issue with the diverters going bad - My boat came with FOUR brand new in the box spares. But in 3 years and over 100 hours I have yet to have one go bad (knock on wood).
rhsj2006 is offline
Old 08-09-2009 | 08:54 AM
make sure your batteries are good, seriously had the same problem, replacedmy batteries and no more issues.
djl7780 is offline
